To set the month and date on a device, you will need to follow the specific instructions for that device. The steps may vary depending on the type of device you are using (e.g., a computer, smartphone, digital watch, etc.) and the operating system or software it is using.
Here are a few general steps you can follow to set the month and date on a device:
Locate the settings menu for the device. This is usually accessed through an icon or menu option labeled "settings," "options," or something similar.
In the settings menu, look for an option related to the date and time. This option may be labeled "date and time," "clock," or something similar.
Select the option to set the date and time. This will usually open a window or menu where you can enter the current month, day, and year.
Use the provided fields or menus to enter the current month, day, and year. You may need to use drop-down menus or arrow buttons to navigate through the options.
Once you have entered the correct month, day, and year, save your changes and exit the settings menu. The device should now be set to the correct date.
A detailed description of this procedure is found in the manual of your watch. You can find the right manual with the module nr. on the back of your watch (4 digit number in a rectangle)
The manual for your watch can be downloaded via the link provided below:
Timepieces Watches
hi Claude. Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
For da only person dat left a comment I figured it out ... The bottom button gives u access to change the time ... Take something hard n pointy and push hard in da middle of da bottom button you have to force the butto in ... And take it from there ....
Press and hold the top left button until the seconds digits flash, indicating that you have accessed the time-setting screen. Press the bottom right button to reset the seconds to "00" and then press the bottom left button to advance the flashing to the hours digits. Adjust the hours digits to the desired time using the top and bottom right buttons. Press the bottom left button to advance the flashing to the minutes digits, and set them to the desired time with the top and bottom right buttons. Press the top left button to exit the time-setting screen. Have a nice day.
Thank you for contacting FixYa.
Setting the Time and Date
To set the time and date on your Armitron digital watch, begin by pressing the "A" button while in time-telling mode. The seconds place will begin to flash; press the "C" button to reset the seconds to "00". Press "B" to set the hour, and press the "C" button repeatedly until the desired hour is reached. Press "B" to set the minutes, pressing the "C" button until the desired minute is reached. Press the "B" button, followed by "C" to set the month, date and day of the week. When you are finished programming the time and date, press "A" to save and return to time-telling mode.
Using the Chronograph
To use the chronograph feature on your digital Armitron watch, press "B" while in time-telling mode to access chronograph mode. Press the "C" button to start the timing; press "C" a second time to stop the timing. To reset the chronograph, press the "A" button. Press the "B" button at any time to return to time-telling mode.
Using the Split Lap Chronograph Feature
To use the split lap feature on an Armitron digital watch, press the "C" button while in chronograph mode. Press the "A" button to measure splits or laps; at the end of the event, press the "C" button to stop the timing. Press "A" once to see the final split or lap time, press "A" twice to reset the chronograph to "0". Return to time-telling mode by pressing the "B" button.
Setting an Alarm
To set an alarm on your Armitron digital watch, press the "B" button twice to access the alarm mode. Press the "A" button and wait for the hours place to begin flashing, then press the "B" button twice. Press the "B" button, followed by the "C" button to set the hour and minute of your alarm. When you're finished, press the "A" button to save the alarm. Press the "B" button to return to time-telling mode.
Using the Countdown Timer
To use your Armitron digital watch as a stopwatch, begin by pressing the "B" button three times while in time-telling mode to access the countdown timer mode. Press the "A" button, followed by the "C" button to set the hour. Press the "B" button, followed by the "C" button to set the minutes and seconds. Once you've set your timer, press "A" to return to countdown timer mode. To stop the countdown timer, press the "C" button. When you are ready to reset the countdown timer, press the "A" button. To return to time-telling mode, press the "B" button.
