Cars & Trucks Logo
Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My remote key fob and the button on the dash, no longer open the back tailgate / liftgate on my 1999 Chevy Suburban. I'm guessing a fuse is blown, but I don't have an Owners Manual to look it up. Can anyone help me resolve this?
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
13505
Points
37
Http://www.extendedgmwarranty.com/owners-manual/chevrolet/1999-Chevrolet-Suburban.pdf this link takes you to an online manual for your vehicle, after clicking on this link go to the "service and appearance care" and then "electrical systems" this shows you a layout of fuse box
Please rate my help, thanks
loginek
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Chevrolet Master 1,075 Answers
  • Posted on Dec 31, 2017
loginek
Chevrolet Master
Level 3:
Renaissance:
Answers
1075
Questions
0
Helped
1320677
Points
4975
2answers
How can I figure out why my hatch, power lock buttons, and power mirrors on my 03 Chevy Blazer aren't working? And how can I repair them?
bought it like this.
so fob buttons work, but not hatch.
but lock inside locks fail (elect. buttons)
driver and shotguns side both fail, lock sw?
ext, mirrors dead.
door looks in the service manual has 5 pages of schematics, is well advised to read that first
not scanning the PCM/BCM first is never good.
oK if the speed sensor on the car fails, doors will act up. (for sure if it see car moving and is not)
the radio receiver (fob) works mostly
Fuse MIR /LKS must not be blown door buttons fail
why not check all fuses, save work and not need books to fix it if a fuse blew.?(underhood box)
IP fuse PWR/LKS not blown
the BCM runs the 3 Door lock relays
possibles
Fuse MIR /LKS blown 3amps
this kill local door power to LF and RF door swithes dead. and Rear glass to. the relay board does not fail with fobs. is the key fact.
your post is not clear on all for doors.
or LF an RF door switches. but assumed both are dead, me.
so it is just blown fuse.
we always check fuse first. a 20 cent part.
What is wrong with my 2015 Suburban tailgate? The fob and front lift button only lift the gate 1/4 and then it shuts.
Liftgate control moduel uses sensor inputs to control the it , maybe one of these sensors is bad . Having a qualified repair shop hook up a professional type scan tool an check for DTC'S - diagnostic trouble codes in the lift gate control module would be the first place to start
1helpful
2answers
The liftgate will not open manully
check if the cable running towards is is still ok and in the right position
2007 CHEVY SUBURBAN- TAIL GATE WILL NOT LATCH
Try changing the liftgate latch. If you have power liftgate, that is the usual fault by experience. There is also possibility for the other associated components to fail, but they are more costly. You can go for these repair while the gate is not yet stuck closed, so you can easily remove the trim panel. However, I still suggest a preliminary check up on the circuits. The fuses, switches, modules, codes, etc. If the liftgate seems to be operational, except for the proper closing and initial opening, its most likely the latch. I just hope we get lucky on that. Okay, there? goodluck. : )
Have a 2002 chevy suburban, liftgate window will not open
Sounds like you have a wiring problem to your liftgate. Check the wires where they come out of the body, and go into the liftgate. If they are good, check fuses, or possibly a module.
1helpful
2answers
Central locking
To re programme your key if your fob has three buttons is as follows. Turn the ignition key in quick succession from off to ignition on 4 times. You should hear a chime to indicate programme mode. Quickly remove the key and press the lock button followed by the unlock button. Wait until you hear the chime again and see if the fob works. If it does not operate the central locking, see if you can open the tailgate with the fob, I guess you have a three button remote? If it doesn't, repeat the above but quicker!! it should programme quite easily. When you checked the fuse, did you take it out? I suggest you remove the fuse and wait 30 seconds and put back in, get someone in the car to see if any doors respond to you replaceing the fuse. recheck the fob operation and the key, this maybe the answer.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
