go to apps look for a program called clean master 14.15 mb
this allow you to transfer about all software to a flash driver or micro sd card, you need software the allows you to transfer phone programs running on the phone to run on the sd card.
You will have to transfer your contacts one at a time. To export a contact's phone number to a Subscriber Identity Module (SIM) card in a BlackBerry smartphone, complete the following steps:
Open the Address Book application from the BlackBerry smartphone Home screen.
Click the contact that you want to transfer to your SIM card.
Highlight the phone number you would like to transfer.
Display the menu on the BlackBerry smartphone.
Click Copy to SIM Phone Book.
Make sure that you are attempting to transfer the correct informaton to your SIM card.
Display the menu on the BlackBerry smartphone, and click Save.
you may be able to use the bluetooth to transfer all your files but i am not 100% sure . i do have a blackberry 8110 pearl and can do it with bluethooth .
give it a go but depending of the model it may or may not work .
When you put them on your card they are just that on your card (may not show up on your playlist) Some phones (like my blackberry and pocket pc) you have to add them to the card then go directly to the memory card to play them from your phone. There should also be an option to add your songs from the memory card to your playlist. Try selecting the memory card (through your phone) and checking the options to see if one says ad to playlist. If not do the other way around. Go t your playlist and add songs (from the SD card) if should ask you from where and you can select the memory card. All else fails you can go to any cell phone store and they can do it (its easier to do it looking at the phone then over the pc...smile)
make sure you are just transferring contacts with phone numbers and nothing else (email addresses et. etc. ) also make sure the area code is included(even on local ones) take the parrot's battery out for about three minutes, do the same to the blackberry) should fix....enjoy
If you have a blackberry pearl 8130 then the Memory card slot should be on the left side of the phone above the application key. If it is a 8110 the memory card slot will be underneath the battery. Hope I helped. Oh and I don't believe you can put the memory card into the MacBook, you have to transfer files with the bluetooth on both your phone and your Mac.
