Samsung MH050FXCA2A 24000 BTU 2 Ton Dual Zone Mini Split Air Conditioner Logo
andre c Posted on Oct 02, 2013
Ive reinstalled a samaung 24000btu split unit i have power to the outdoor unit but the indoor unit doesnt switch on
Sandeep Biswal
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 20 Answers
  • Posted on Oct 02, 2013
Sandeep Biswal
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
20
Questions
0
Helped
2281
Points
60
Please again reinstal and see if not work then buy a new one
3 Related Answers
drsn
David R Sannicolas
  • 42 Answers
  • Posted on Apr 16, 2010
SOURCE: My Outdoor unit not starting ... but indoor is running fine
check the capacitor. it might be defective, i would have a certified electrician or hvac tech trouble shoot it..if you never had worked on a/c b4...........you could probably ruin it more....................if you dont know what your doing......
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Jan 02, 2011
SOURCE: my split type ACU .the indoor lights are blinking
You didn't mention what error code it shows. But with your statement, please rotate manually your blower motor. If hard replace bearing or motor. If It rotates freely. replace room and coil sensor in indoor unit.
Anonymous
  • 127 Answers
  • Posted on Aug 24, 2011
SOURCE: I have a contractor that
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
I have an lg split system with 4 cieling mont units model# LMU540HV ITS BEEN WORKING FINE FOR YEARS now when i turns on it will run for 2-3 min. Then flash 5 time ive ive checked voltage alls good lights...
According to an LG installation manual for the LMU540HV, if the flashing light is viewed on the indoor unit with the ceiling cassette light on the far right flashing 5 times, it is an error code meaning there is a communication error between indoor and outdoor units. I would start by making all indoor and the outdoor units have power. I would especially check to see that fuses or circuit breakers to the outdoor unit have not failed. Or check the outside disconnect to make sure it is working. Check with a volt meter to be sure you have 220 volts present to the outdoor unit. Also, if the 4 indoor units have emergency power off switches, make sure all 4 are turned on. Checking to see power is present both indoors and outdoors a good place to start. It the outdoor unit has power, there may be a relay that has failed or a power circuit board has failed that would cause it not to communicate.
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
How to check MSG12HRN1W MINI SPLIT SYSTEM electronic board
If your mini split was installed to meet most building codes, an inside disconnect switch should have been installed. This switch breaks the power and signal from the outdoor unit to the indoor unit. It is not the same as the outside disconnect to the compressor (outdoor unit). If it was turned off, the inside unit would be dead. Look for a disconnect switch inside your room. By code is should be within 15 feet of the inside unit.
LG SPLIT SYSTEM AIR CONDITIONER INDOOR UNIT WILL NOT POWER UP
as described the voltage you are seeing is fake. if there is no led lighting in the indoor unit check the small transformer in the indoor unit you should get 12V DC or 24V DC out from it
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
The supply is 220v going to pcb. indoor .the outdoor unit was not working due the power supply..was 110v,, prom the pcb indoor..
I assume you are in Australia? There should be a 240v feed to the indoor unit. Once the indoor unit has been switch on , there shouldbe a 240 v supply to the outdoor unit. The communications wire will fluctuate what voltage is supplied to the outdoor. Unless you are a licenced electrician, I would not suggest you attempt to check these figures as the risk of electrocution is very high. No power to the outdoor unit can be as simple as a failed air / pipe sensor on the indoor unit , or the indoor board itself is faulty. Call up an LG Agent in your area for service and to protect your welfare..
2answers
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
2answers
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
