20 Most Recent
Samsung AW1203B Air Conditioner Questions & Answers
My samsung window ac ,at
It is not a problem it is just the reminder to clean the filter of the
a/c this error display automatically every after 336 hrs, so just clean
the filter and reset the CH display by pressing temp up and down arrow
key to reset it
When a air conditioner freezes up can one put it on fan low speed
If the unit is freezing up then you have a problem. One is the air flow is to low going through the evaporator coil this could be caused buy a dirty filter, dirty coil and fan blade or low freon charge. the lower the fan speed the colder the coil temperature. the coils and unit should be cleaned every year. running your unit on low is not a good idea.
My air conditioner worked fine
If your air conditioner displays E1 in the display
panel and won't turn on, it means that the Room Thermistor (a device connected
to the thermostat that detects room temperature) is shorted or defective, and
you need to have your air conditioner serviced
"Ch" is displayed on the display
just press the arrow keys up down and hold it for few sec till beep
comes..(on ac scree not on remote)... this indicates cleaning of air
filters..
If problem still persists, let me know.
Thanks.
Code E1 on my Samsung AW1204B Air Conditioner
Found this on Samsungs site.Hope it helps a little, at least you know the problem now.
If
your air conditioner displays E1 in the display panel and won't turn
on, it means that the Room Thermistor (a device connected to the
you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To
arrange for service, contact Samsung Customer Care at 1-800-Samsung
(1-800-726-7864). Have the model number of your air conditioner on hand
when you call.
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Greeting,
I have problem with SAMSUNG
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
Error e4
Check you Freon for low pressure or the low pressure switch.
L5 code
look for sensors, room @ coil
