Worldwide 1995 Oldsmobile 88 Royale LSS 3.8L Alternator - 140 Amps Logo
Kim Reddig Posted on Sep 29, 2013
1995 oldsmobile cooling fan don't work - Worldwide 1995 Oldsmobile 88 Royale LSS 3.8L Alternator - 140 Amps
ray davis
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 05, 2013
ray davis
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
327
Points
Change fan motor put 1 on my buick for like 25.00 its a cheap and easy fix just unbolt whole fan pull out and unbolt motor its only 4 screws vry easy fix..
2answers
Where is the relay box for the cooling fans on the olds silhouette 95
The relay's are located under the rear seat on the drivers side of the vehicle.
Cooling fan(s) wiring diagram
Its either t Cooling Fan Switch ABCDEFGHIJKLMNOPQRSTUVWXYZ Inspect/Test/Replace
To find the RADIATOR COOLING FAN MOTOR RELAY, we need additional information about your 1995 Oldsmobile Aurora 4.0L SFI DOHC 8cyl.
Please select one of the following:
The Radiator Cooling Fan Motor Relay is located: Under hood, passenger side, upper firewall, mounted in corner in relay block
When testing a cooling fan switch, first test it with the engine cold, then test it when the engine reaches a specified temperature. Check your vehicle's service manual for more directions.
To check a switch, disconnect the connector at the switch. with an ohmmeter, check for continuity between the terminals of the switch with the switch moved to the on position and to the off position.
The Radiator Cooling Fan Motor Relay is located: Under hood, passenger side, front side of wheelwell, mounted in relay panel
The continuity through a switch can be checked with an ohmmeter. With the switch open, there should be infinite resistance. With the switch closed, there should be zero resistance. With the switch off, there should be no continuity between the terminals. With the switch on, there should be good continuity between the terminals. If the switch is activated by something mechanical and doesn't complete the circuit when it should, check the adjustment of the switch. (Some switches are not adjustable.) If the adjustment is correct, replace the switch. Another way to check a switch is to simply bypass it with a jumper wire. If the component works when the switch is jumped, a bad switch is indicated.
Voltage drop across switches should also be checked. Ideally, when the switch is closed there should be no voltage drop. Any voltage drop indicates resistance and the switch should be replaced.
he fan motor,the fan switch,or the coolant temp.sensor.
1helpful
Cooling fans will not turn on
most likely need to replace the coolant temp sensor. sensor is located on the driver side on the head closest to the firewall.
1helpful
The Cooling fan unit of my 1995 Oldmoble Cutlass Suprem does not come on at all
The Radiator fan? if so I would hard wire it to your battery to see if it works at all.
from there it can only be a sensor problem.
Or if the fan does not work at all..... it is the fan.
The radiator fans aren't working on my 1995 oldsmobile, and it's running hot, is it fan motor or the heating sensor?
FIRST SCAN CAR TO SEE IF COOLANT TEMPERATURE SENSOR IS WORKING SEE IF YOU GETTING ECTS CODES. IF NOT CHECK THE COOLING FAN FUSE AND RELAY.IF BOTH GOOD HOTWIRE THE COOLING FAN USING JUMPER WIRES TO CAR BATTERY.IF FAN DONT WORK REPLACE THE COOLING FAN MOTOR ITS FAULTY.
2helpful
1995 cutlass supreme. There are two cooling fans.
it will come on but only when the engine is very hot and the first fan cant cool it down that fast,, its turned on by a difrent heat censor so the engine needs to be realy hot to set the second fan running and it may even then only run for 30 seconds till the engine temp drops off,,, as long as the car is running in the normal heat range dont worry about it,,, if its cooking way up in the red,,,,,now worry about it,,fast too,,
Top Worldwide Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
