The first link may help with locating your pressure switch what it is and what it does, the second link will show how to locate and clean a pressure chamber
http://www.selfix-uk.co.uk/Video_page_Hotpoint_pressure_switch_explained.html
http://www.selfix-uk.co.uk/Video_page_washing_machine_pressure_chamber.html
SOURCE: Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
SOURCE: Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
