SOURCE: Replacing tip
i have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
SOURCE: Weller 8200 100/140W replacement light bulb?
The bulb's part number is 7333. You can order a replacement bulb here for about $2.50 :http://www.e-sonic.com/aboutus/cat/S/soldering%206.pdf
Testimonial: "Thank you. Bulb voltage is actually whay I was looking for but I did not specifically ask for this.:-) Perhaps a 7333 bulb is a universal #."
SOURCE: Need to download a manual for the Weller universal
just type in weller 8200 sol gun in search and it will go there
Testimonial: "After many futile tries on my web browser, your recommended web address contained the answer I was looking for. Thanks alot."
SOURCE: Are there instructions or a manual available for
The manual is available here: http://www.cooperhandtools.com/onlinecatalog/Operating_Instructions/D550-8200_Gun_Instructions.pdf . This is the manual for the Weller 8200 and the D550.
I hope this helps.
Testimonial: "Thank you so much for the instruction information for the Weller 8200 - this will be very helpful. "
