Whirlpool MH7155XM Microwave Oven Logo
Posted on Sep 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stove Light The stove light that is integral to the microwave will not work. I have checked continuity for all wires but not getting any electricity to the bulbs. The button beeps when you try to turn on the lights but nothing happens. All other buttons on the keypad work fine. Any ideas?
  • 1 more comment
  • Eric3405 Sep 20, 2007
    Bulbs are good. No sure what the light switch in the door has to do with the lights over the stove? They are controlled by the switch on the panel and go on and off regardless of the microwave door being open right?
  • Eric3405 Sep 24, 2007
    MicrowaveSvc - Ok mailing it off to you today!
  • Anonymous Jun 20, 2008
    Stove Light under Whirlpool Microwave doesn't work either. Everything else on microwave and panel works. Service person said the whole control panel has to be replaced. Said something was wrong with a relay? Don't know what it's going to cost.
William Miller
Level 3:
  • Whirlpool Master 9,179 Answers
  • Posted on Sep 23, 2007
William Miller
Whirlpool Master
Level 3:
Answers
9179
Questions
Helped
4481858
Points
21747
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Full information is at at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
A
Anonymous
Fulout the cover, right side, look the switch under the bulb.good luck
Anonymous
Level 1:
  • Contributor 67 Answers
  • Posted on Sep 19, 2007
Anonymous
Contributor
Level 1:
Answers
67
Questions
Helped
24483
Points
69
Try to fine the light switch in door and check the bulb
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
The over the stove cook light button is broken.
The screws of the lid are located at the back and bottom of the oven.
1helpful
How to install a electric line for over stove micowave
This is usually best left to a licensed electrician, however in some homes there is already electrical wiring over the stove for an exhaust fan. You might be able to tap into the exhaust fan wiring and install an outlet that you can plug the microwave into, or if there is an electrical outlet near the stove area you might can tap into it just be sure that you are not overloading the outlet. For example if there is a refrigerator or other major appliance using power from this outlet it might not carry enough current to operate the refrigerator and the microwave at the same time and will cause the circuit breaker to open or fuses to blow.
2answers
Microwave GE JVM1631
The control board is bad. Good Luck
Microwave
Replace the control board, It is bad. Good Luck
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
