When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt monthly. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine. -
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
The following link will take you to our tech support page that contains some tips and videos on how to maintain your treadmill:
SPORTSMITH LLC
SOURCE: The circuit breaker trips when i get over about
hi, firstly if you are using a extention wire unroll the whole thing, and putting a higher amp volt in the plug. this should help
