SOURCE: Printer
#334 is an eprom error, try turning it on and off to reset it, if it doesn't work there might be a problem with the main logic board.
SOURCE: canon mp370 error 5100 cartridge jammed...please
Hi You can Try
Error Code 5100
Hope this works
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Testimonial: "Ok, i'm back! Thank you!!It's amazing to know people are really out there to help. I followed instructions, didn't have to remove side & Voila! "
