Efficient Networks SpeedStream 5667 Modem Logo
A
Anonymous Posted on Sep 17, 2013
Speedstream 5667 reset - Efficient Networks SpeedStream 5667 Modem
1 Related Answer
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Oct 12, 2010
SOURCE: I have reset the modem
Sounds like you try-ed to firmware the modem and it failed, what we call a brick, the only thing you can do is try again if it does not work looks like a replacement modem will need to be ordered.
You simply cannot recover a bad eprom in these.
Hope this helps please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
tip
Drivers
Buenos dias donde puedo obtener gratis los drivers para un speedstream 5667 se me extravio el cd gracias
Felix.
help need drivers free speedstream 5667
I need the usb driver for the 5667 for xp
Here's what I found:
http://www.dslreports.com/faq/16029
Hope it helps!
1helpful
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
Speedstream 5667 Ethernet ADSL Modem
My guess may be you are looking for Telephone cable which you need to connect it to a wall outlet for internet line. You can purchase it any hardware shop or at an electronic shop.
Thanks.
PC to PC connection
Question is already answered. I asked members of our local computer users group.
3helpful
Drivers
On THIS page look for the link to file 5667USB34.zip it should be the USB driver you need.
Ensure you virus scan the file prior to unzipping as I cannot verify the file is safe or what you want.
No connection
Did you install the line filter to isolate the dsl side from plain telephone signals? Telephone equipment can interfere with dsl signals if the proper filters arent used. Read this: http://www.hometech.com/learn/dsl.html
Reset accidentily and light power usb ethernet is blinking
Settings have been reset, call your ISP to have them help you go through the configuration again.
Will not connect
First, I would make sure you are using the right type of patch cable to connect to your cable/dsl modem. There are two types: 1) Straight through 2) Cross over The manual for this device says to use #1 when connecting directly to a computer, and #2 when connecting to a hub. http://www.fltg.net/Software/5667B%20Quick%20Start%20Guide.pdf If the cable/dsl modem is powered on and you are not receiving a link light on either the cable/dsl modem or your computer, try using a different cable. If this does not work, then you may have a problem with the device itself. At that point, call your Internet Service Provider, as they may be able to provide you with a replacement. If you did not receive this device from an ISP, then you will have to contact the manufacturer directly. Unfortunately, it looks like Efficient Networks was bought by Siemens, so you may have a hard time receiving support from them. http://www.efficient.com/ http://subscriber.communications.siemens.com/broadband_family_frame.htm
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
