Canon Rebel XT / EOS 350D Digital Camera Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Digital Rebel XT: error 05
When I try to take pictures in the standard mode I get an error 05 message. I have read in my manual that it means something has obstructed the automatic flash pop-up, however, my flash has popped up. It pops up and then the release lever for the flash clicks twice. The manual says to turn the camera off and back on. It does the same thing (but clicks three times instead since the flash is already up). I am able to take pictures on other settings, just not the automatic setting (green box). Can I fix it on my own or do I have to take it to a dealer?
  • 6 more comments
  • richw Dec 27, 2007
    Hi
    yes getting the 05 error but the falsh unit seems to have just jammed shut so cannot view inside to see if th pins are dirty or bent.
    Camera is just over a year old.
  • Anonymous Aug 18, 2008
    i have the same problem
    who knows how to handel it?
  • Anonymous Dec 30, 2008
    Thanks...same prob, but after messin' with it for a few, a few q-tips and some alchohol, problem is solved...
  • Anonymous Jan 17, 2009
    thanks guys, I got the same problem and it was solved with the same method. One stick on the left of the light got stuck. I use Q-tip and alcohol (actually i didn't have alcohol, so i used mouth rinse) rubbed around it then pushed it. It worked perfectly.
    Thanks again
  • Anonymous Jan 24, 2009
    I could not figure out to save my life why my Rebel's flash would not work. I dreaded having to send it in to Canon to be fixed, but you guys were right!! It was the small pin and it just needed cleaning... I would never even think about taking my camera apart so REMOVED the battery and went through 5 Qtips dipped in dripping alcohol. at first the pin was stuck and would not go down but after slightly pressing and continued wiping it finaly came free and now my camera works just as it should..
    If someone reads this,, before you use any type of liquid cleaner be sure to remove the battery!! and don't over-force the pin..
    Thanks Guys!! I just added FixYa to my favorites.
  • shooter48625 Jan 26, 2009
    I have a canon digital rebel xt / 350D and i dropped it and know with i put it on the auto function the flash will not pup up and i get error "99" how can i fix the problem or how much will it cost to be fixed, could the flash just be jammed. can i replace the flash my self
  • Anonymous Jan 26, 2009
  • Anonymous Mar 09, 2012
    I've cleaned the pins and flash parts and now the flash is popping up nicely. I'm still getting the Error 05 though?? When I go to shoot, the flash pops up right away, and then about a second later I get the Error 5 message. Not sure what's up.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
18270
Points
13
I had the sticking and two-clicks problem also. I manually pulled the flash up, then took a Q-tip dipped in standard rubbing alcohol and ran it over all the sliding mechanism parts of the flash. Then I rubbed the dry end of the Q-tip over it all agan and it now works fine.
  • Anonymous Jun 02, 2012
    My camera is one of the original EOS Rebels, an XT. I don't see any pins and don't want to force the flash and break it. Any other suggestions?
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Sep 16, 2007
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
53927
Points
53
I have some experience on this problem. CHECK THE FOLLOWING BEFORE SENDING THE CAMERA TO REPAIRING. When the flash unit pops up a lever sends a signal to the camera. Try to pop up the flash, CHECK THAT THERE ARE "two" PINS ON EITHER SIDE OF THE FLASH. A longer one just appears "behind" the latching hook ON THE "RIGHT" OF THE CAMERA. IF THE LONG PIN IS BENT, DOES NOT POP UP OR EVEN MISSING TO LEAVE IT A HOLE, THEN THAT'S THE PROBLEM. It can be "repaired" by one-self (like I had did so) but you have to learn to dissemble the back, the front and then the top cover. If you have some skills, then NO PROBLEM.
  • Anonymous Oct 29, 2011
    I cant believe THAT was the problem uGH! thanks!
    Where is this shoe and how do you pop it up?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16984
Points
12
Solution #2 & #3 were right on the button!!! I had never noticed that ''small''round button on the left side.It was stuck flush with the body and just giving it a chance to come out and cleaning it was enough to get the flash and the camera working properly again.
Anonymous
Level 1:
  • Posted on Dec 27, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16984
Points
9
I had this problem also and after reading the above post Iooked at the pins under the onboard flash and sure enough one was sticking from built up dust and sweat and gunk. I took a Q-tip with some mineral oil on it and kept cleaning around the pin and kept trying to get the pin free to move up and down smoothly. After about 15 minutes it was freed and the 'Error 05' was no longer a problem. The camera works perfectly once more. So if this is your problem - a pin sticking - try this cleaning before sending it in or disassembling the camera yourself. Thanks, Rick
Anonymous
Level 1:
New Friend:
  • Posted on Nov 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16984
Points
5
I just had the same Error 05 message, right after cleaning my camera. I thought it was something I did while cleaning it. I called Canon and was sick to my stomach when they send I'd have to send it in. I know Canon makes a good product, but I had a previous bad experience with their service department and dreaded the thought of going through them, and money, and time without my camera again.
Determined not to mail my camera off, I found this website and all the helpful advice. Sure enough, the pin I never knew was there - was stuck half way and popped up when using rubbing alcohol and a Q-tip. Kudos to the website and the advice!!!
zdenek vajdak
Level 2:
Champion:
  • Expert 206 Answers
zdenek vajdak
Expert
Level 2:
Champion:
Answers
206
Questions
0
Helped
90549
Points
353
Pop up flash locking mechanism needs adjustment or to be replaced . You might be able to do this yourself but the top cover has to come off completely ( the mechanism I am talking about is on the inside of the top cover and is not expensive ). One reason for sending it in is that if the mechanism ( small electro magnet and the lock ) has to be replaced you will need spare parts and these are not freely available.
Anonymous
Level 1:
  • Posted on Mar 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
16984
Points
Hi.I looked at the suggestions above and it is easy...If you have a canon eos 350d with a flash error 05 message then simple manually lift the flash up.... it exposes the two sliding levers and the locking pin. . simply wipe them with lint free 'bud' stick or cloth and for good measure balst it with an air duster .. which you can buy in cans... it clears any dust or grime .. the mechanism then works perfect.. end of prob and no seneidng it away for expensive repairs.... if you ring canon uk up they will advise you to send for a repair... but its easy to do so do it yourself.. dont be heavy handed on the sliding pins when claeaning but they shouldnt bend easy... . its simple enough to do.. .
pattyrish
Level 1:
New Friend:
pattyrish
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
16984
Points
I was so skeptical this would work - it sounded too simple. A Q-tip with a little rubbing alcohol and 30 seconds later my camera worked! Wow, I was dreading another bill to fix my canon. Thanks for sharing and saving me a bill for a photo shop to take a look at it. I'm sure they charge a hundred fold to fix this simple do-it-yourself job!
Anonymous
Level 1:
New Friend:
  • Posted on Aug 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16984
Points
As stated above, a Q-tip and a drop of rubbing alcohol. You can open the flash by holding the SIDES of pop-up flash unit. Don't pull up on the front, it won't work... you will understand why once you pull it open from the sides. My problem wasn't the pin, it was an itsy-bitsy tiny drop of sticky something. We last used it at the A's / Yankees game, so it could have been anything. A quick clean up with a Q-tip and a drop of rubbing alcohol, works perfect.
Anonymous
Level 1:
New Friend:
  • Posted on Oct 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16984
Points
How can i fix error 05 of canon digital 126181 EOS 450D
A
Anonymous
Hey thanks for the info guys especially the point about the long pin (switch) on the right side (if looking at the front of the camera) mine was pushed in or cruded up - cheers chansimon. I also cleaned the shorter pin (switch) under the hot shoe frame (the rails where you would connect a bigger flash)located (if looking at the front of the camera) on the left side of the hot shoe (see here for picture).
I would also like to mention that if your having problems getting the flash to pop up try taking the top plastic off the on built in flash (open flash and take three screws off) and grease all moving joints where friction could occur. When i say grease i mean very very very lightly, i used white door grease, use something that is going to stay there for awhile, something thick. Now i was still having problems getting it to work so i took the spring out and with needle nose plyers pulled on it just enough to make the spring a tad stronger. You know in the opposite direction. Becarefull doing this you don't want to warp the spring. I suggest grease first and play around with the alignment and tension of the screws before the spring method.
Anyway, thanks so much, i would have never have saw that second switch. You gotta love the net, eh!
Gordon
  • mcmusser Dec 11, 2010
    Thanks for the photo! Worth a thousand words...
Anonymous
Level 1:
  • Posted on Jun 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16984
Points
Pull the flash up manually and spray some lubricant on the hinge, that worked for me.
Anonymous
Level 1:
  • Posted on Aug 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16984
Points
I had the same '05' flash error and 3 clicks..googling the problem brought me here and I cleaned out around the flash with a qtip like suggested and guess what.. It works!!! Woohoo!!
I take photos at a local dirt track so I have no idea how it got so dirty (JK) but thanks to you guys I'm ready to back this weekend!
Big Thanks!
Anonymous
Level 1:
New Friend:
  • Posted on Jul 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
18395
Points
How to fix a broken internal flash on a Canon Rebel!!
Error code e05
wow, didn't think this would work, but used a soft tooth brush to dust around under the flash and a tiny little ... very little pin sized pin :) at the very back left under the flash popped up!
it works now. The pin is so small you can hardly see it at the back there, but
it seemed to be stuck down inside and the soft tooth brush helped it pop back
up into place!
My camera is fixed! Thanks so much!!!!!
Error code E 05 Cannon Rebel T1
Flash pops up but wont take a picture when a flash is needed.
Flash was broken now it is fixed!! Thanks everyone for your help!
A
Anonymous
Just used the advice above... fabulous!
You can lift your flash up... just use both fingers on the sides and it comes up.
Then clean all around the lifting levers etc... And after many attempts and cleaning as suggested above, it is fixed. THANKS! just brilliant!
A
Anonymous
The problem is i cant even lift my camera pop up flash manually.... it is jammed!
A
Anonymous
I just cleaned the sliding mechanism and it was the small round pin on the left side. Thank you so much for posting your suggestion....I was a little scared there. I haven't had my camera for a year.
A
Anonymous
Thank you all so much! This is my brand new camera - and I thought I must have done something to break it yesterday. Q-Tip and a tiny bit of rubbing alcohol worked wonders. Now the flash pops right back up!
Anonymous
Level 1:
  • Posted on Oct 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16984
Points
My problem is after turning the camera off then on again, it completely died. So I charged up the battery, took two pix and it died again. Recharged the battery, camera is still dead. Used a different battery, still dead. Not looking too good is it?
Anonymous
Level 1:
New Friend:
  • Posted on Dec 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16984
Points
This solution was so simple, just a q-tip with rubbing alcohol to fix it. I was told this would cost me somewhere in the $200 range to fix for a 5 year old camera, I was thinking it was more worthwhile to purchase a newer model. Well, it only cost me a drop of rubbing alcohol and a q-tip. My pin did not pop back up after applying the rubbing alcohol so I lightly poked it with a small screwdriver and up it came. The pin should stick up above the housing of the camera about 1/8th inch.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16984
Points
On 450D, if you popup flash, there is a small black micro switch on the left hand side under where the flash rests when closed (Facing camera.) Using your fingernail, a gentle flick should release it so it pops up again. Other users have suggested alcohol and a q tip to remove any dirt that may have caused the switch to stay down. Either, way the switch should be in the 'up' position when the flash is open.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16984
Points
Wow you guys are so helpful... I was thinking of sending my camera to Canon to be fixed (error 5) but I found this site, did what you all said and BINGO it works!!!! Thanks so much.
  • Anonymous Apr 01, 2012
    Great solution!! For the longest time the pop-up mechanism on my camera wasn't working (and giving an err 05), and I was using my fingers to lift up the flash. Then the flash itself refused to work..Now after reading this forum I realized that the problem is the pin (on the right side, underneath the flash mechansim) which doesn't pop up. I cleaned it using a q-tip and some alcohol, and viola it works now!! I still have a problem with the pop-up mechanism - will need to open the flash & adjust/lubricate the springs...Thank you FixYa!!
Anonymous
Level 1:
New Friend:
  • Posted on Nov 29, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
16984
Points
I have error 537 on canon eos rebel xt. It doesnt flash
Canon EOS Rebel XT Error 05 or BUSY
The Error 05 means the build in flash cannot be raised.
In the moment it should pop up, something was blocking the free movement. Could be caused by the way you were holding the camera. Could be happening, while you were pressing the flash button, or when you are in the basic zone shooting mode, such as portrait, which needs the use of the flash.
Switch the camera off an then on again. Move an eventually cause of the blocking and press the shutter realise button again.
I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
Sai.
2helpful
2answers
2helpful
Spot Meter on Canon Rebel XT?
there's a metering mode setting.
from the manual:
(metering mode on first menu1)
evaluative metering - standard setting, takes account off all areas of scene.
Partial metering - effective when background is much brighter than the subject due to backlighting etc.
Centre weighted average metering - the metering is weighted at the centre then averaged for entire scene.
pressing the right hand button of the two little ones top right corner of camera brings up display on lcd, using thumb wheel you can select where the metering takes place. in the viewfinder the display lights a red dot for areas selected.
Try these settings to see if this helps in your situation.
2helpful
2answers
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Error Message
Error 5 indicates - Something is obstructing the built-in flash....
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
