There is a difference between installation of workstation an server so you will need Dell installation CD for power Edge series of servers, you can download ISO image here from this link so download ISO image burn CD insert that CD on server and follow procedure.
Power Edhge Installation
SOURCE: Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
SOURCE: high pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
SOURCE: power edge loght is red and blinking
You
should be able to see the reasons in the front panel, remove the
front cover and you will see a small display with some information
passing slowly. Sometimes is just the redundant power-supply that is
disconnected.
