I have printmaster version 18 platinum i would like to do the custom installation but i do not see that choice, this is my 5th try at installing print master can you help me please? Thanks rs. Vauna Jones
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 16, this is the link http://support.broderbund.com/fix.asp?isid=44677&prog=1294820935&printer=1
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 18, this is the link http://support.broderbund.com/fix.asp?isid=44677&prog=1294820935&printer=1
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed.
If possible download .NET framework 1.1
If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Unfortunately, the 'New' PrintMaster 2011 will not import any older PrintMaster .sig files created prior to PrintMaster 2.0. This means that over 1,100 projects I have,going back to 2004 are now useless. Did they even consider this before coming out with the new version? Is this the way that Broderbund treats long time customers of their product? Apparently so...so I will no longer be using any of their products from now on. I don't see any excuse for their actions.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
i couldnt locate one on the new but if you launch the program it will have a help feature under the list on the MENU bar on printmaster you might have to print it... or call Broderbund for a replacement ... you might even fine one on ebay ....
Note that there is a "pop-up" window that gives you 20% off their price ($34.95) if you buy online within one hour of _first_ viewing the above web-page.
