Lands Phones Logo
Posted on Apr 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Retrieving messages over phone
HOw can I retrieve messages from my panasonic KX-TG 6700 calling in from outside?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Apr 14, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
10936
Points
91
Using the answering system
remotely
1 Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code The default setting is “11”..
LThe unit plays back new messages
including memo messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
necessary.
4 When finished, hang up.
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
Note:
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 10 minutes of recording time
is available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can select the desired line(s) and
press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
you.
1 Select the desired line(s) while you are
accessing the answering system if
necessary.
For line 1: {#}{1}
For line 2: {#}{2}
For line 1 and line 2: {#}{0}
LAfter selecting the line(s), memo
messages do not play.
2 Press the desired dial keys.
Key Remote command
{1} Repeat message (during
playback).*1
{2} Skip message (during
playback).
{4} Play new messages.
{5} Play all messages.
{9} Stop recording/
playback.*2
{0} Turn answering system
off.
{*}{4} Erase currently playing
message.
{*}{5} Erase all messages.
{#}{1}{7} Record a greeting
message for line 1 only.
{#}{2}{7} Record a greeting
message for line 2 only.
{#}{0}{7} Record a common
greeting message for both
line 1 and line 2.
{#}{1}{8} Turn answering system
on for line 1 only.
{#}{2}{8} Turn answering system
on for line 2 only.
{#}{0}{8} Turn answering system
on for both line 1 and line 2
*1 If pressed within the first 5 seconds of a
message, the previous message is
played.
*2 To resume operation, enter a remote
command within 15 seconds, or the
Turning on the answering system
remotely
If the answering system is off, you can turn
it on remotely by calling the selected line in
“Turning the answering system on” on
page 40.
1 Dial your phone number.
2 Let the phone ring 15 times.
LThe unit answers your call with the
greeting message.
LYou can hang up, or if you call from a
touch tone phone, you can enter your
remote code and begin remote
operation
Anonymous
Level 3:
  • Master 600 Answers
Anonymous
Master
Level 3:
Answers
600
Questions
Helped
113887
Points
1617
When your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Answering machine retrieve messages
You may download a copy of the manual here.
"Listening to Messages" begins on page 57.
How to retrieve messages on this phone
my owners manuel has code to use .works the same as when you call yourself to get messages when in town,also manuel has code to erase messages very handy when out of town.
4helpful
3answers
I have a panasonic KX-T7665 how do I forward calls to my mobile
The simple answer is on the intercom dial *7102 9 number #. That forwards all calls outside. However, outside line and trunk-to-trunk programming has to be programmed into the system.
There are other conditions located in the Operating Manual under Call Forward. In mine, it's on page 71.
Carl
1helpful
How do I reach my voicemail on the Panasonic KX-T633? When I press the 'message' button it just calls another extension.
This button is to "
MESSAGE:
Used to leave a message waiting
indication or call back the party
who left the message waiting
indication.
" not retrieve a message.
Here is the manual http://www.reachcom.com/manuals/Panasonic_KXT7625_30_33_36.pdf
There is no voice mail in the phone.
1helpful
Suddenly have voice mail messages on handset (beeping before dial tone) when hooked to external voice message machine. I am using Vonage as my company.Panasonic hands free hooked to 4 handsets. Model is...
vonage gives you a personal voicemail. You should contact them and find out how to retrieve it first. If you have your companys voicemail on the panasonic you should also make sure that vonage voicemail get longer waiting time.
2helpful
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • 0helpful
    Remote message retrieval
    If you have a Panasonic brand voice mail, you press #6 * and your extension, then the password.
    Carl
    How do I retrieve messages left in the operator's voice mail?
    If you pick up the handset and press the button it will call back whom ever left the message. (that extension you see.) If it is not the voice mail extension, it was just a request to have the receptionist call back. Doing so should clear the lamp.
    Top Lands Phones Experts
    k24674
    Are you a Lands Phone Expert? Answer questions, earn points and help others
