Left indicator not flashing. blinks fast. other indicators and also hazard working fine. bulb is new.
SOURCE: HAZARD LIGHTS ON BUT NOT
HI,
I have the same problem - it is the relay switch attached to and behind the hazard warning triangle on the dashboard. Pull it all out (gently and replace (£60 ish). The indicators and hazard lights are on the same relay circuit. This is a well known problem for this car (amongst others - how about the wipers sticking)
SOURCE: Indicators not flashing on Audi TT
i believe the audi uses two relays for the turn signals and hazzard lights so it would appear the turn relay has failed. it should be located under the dash near the steer column.... seems to me me they have some shielding under the dash so it may be hard to get to.
SOURCE: left rear turn signal light on my 1999 chev. s10 is not working
any increase in bink speed is direcly related to a bulb being burt out.
SOURCE: rear left and right turn signal lights not working.
the electronic flasher module may be faulty, or you could have blown a fuse
SOURCE: Indicator Problem
when you noticed the indicator being on solid, but flashing with the hazards, are you inside your car? I mean have you gotten out of your car to check if the bulbs are working when the indicator thrown and when the hazards are on. A hard on indicator usually means that you have a bulb burnt out. The hazards will still flash as normal when inside the car even if a bulb is burnt out because the hazards do not run via the Electronic Flasher Module. The EFM is what detects a burnt out bulb
