SOURCE: wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
SOURCE: w300 WONT TURN ON WONT CHARGE!
i happen to me you need to find a friend or a family that has the same phone that you have and that your problem solve!
SOURCE: does anyone have sony ericsson customer care contact number for Chennai?
Hi the problem might be in the charger pin or in the mobile charger pin if u have problem in any of the charger pin or in the mobile pin which is used for charging the mobile.
SOURCE: W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
SOURCE: when charging the red light comes on but won't turn on
This happenned to me too, here's what I did:
- plugged in the charger WITHOUT the battery inside,
- then put in the battery (while still plugged in).
- The phone came back to life and works fine now.
Hope this helps.
