I am having Problems with formating samsung mobile E250 micro sd card. Whenever I try to format a card it is giving a error message. Earlier it was working fine but suddenly it has stopped working , so i tried to format the memory card but it did not worked. Can a virus in a computer can have done this when i have connected my mobile to PC. Or can mine memory card could have got damaged. I am using 1 GB Transcend micro SD card.
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
I want to formatting my phone samsung shg-e250 not my micro-sd memory card
I Had the same problem, however it was only the first time. I have a Samsung A711, it came up with a message saying that i needed to reformat it, an so i did, and it came up with a error message.
How to fix: plug it into the computer and right click on the "removable drive" icon then click format. format it normally, now put it back in your phone, and turn the phone off and then back on. now go over to memory usage, it will ask you if you want to reformat, and press "yes" this time it should work.
"i want to formatting my phone samsung shg-e250 not my micro-sd memory card"
the solution is this but be aware that it will erase everything from your phone: *2767*3855#
You will find that most phones except for very new and very expensive only support 2GB expandable memory (ie: Micro SD). They usually don't tell you in the box or manual. 2GB is still pretty good for a phone.
The solution for the problem is quite simple, open up the folder, extract all the folders and files to ur desktop. Then do this, go back into my computer and format it normally, not using quick format. after that just put ur files back on there if u are 100% sure that they are not corrupting the device then wallah it works :) =] i just did it for 2 of my micro sd cards that didnt work properly.
I HAVE A SAMSUNG R560 I JUST BOUGHT A TRANSCEND 2GB MICRO SD IT BEEN GIVING ME WEIRD MESSAGES LIKE SEMPHORE TIMED OUT OR IN TO DEEP EVEN SAYING CANT READ DISC ANYBODY HAD THESE ISSUES WITH THIS DAM THING ANY FIXES OR SOUND DEFECTED
Format now
If you have any problem with formatting, just insert the card then switch your phone off then on. am 100% sure it will work
I think you can try and format the card from the phone itself. Just access your card through your phone, and there should be an option for you to be able to format your memory card.
You just have to change it to mass storage
SOURCE: Problems with formating samsung e250 micro sd card
I had the same problem and I tried everything. I couldn't think of anything else to do so I just turned my phone off and back on again. When I went back to the memory card menu on my phone all the folders that I lost re-appeared. I don't know if it would work on other phones but it's worth a try!
Thank you mixmaster, but i hav even tried formating memory card through PC My computer , but it was giving the message "windows was unable to format"
I have tried it but it is saying windows was not able to format it message. I think this samsung mobile E250 itself is a bad piece with too many defacts............
problem that memory card not access through moblie samsung sgh-u700
Mine won't work either I even bought a new one. I think it is a problem with the OS. Anyone got a ny patch solutions for installation drivers. My restore disk does not have installation or formatting drivers included. My only foreseeable solution is a full format. Booooo.
Hey.. I am also havinh trouble uing my memory card with my E250 mobile. When I first got the card and put it into my phone and put songs onto the memory it worked perfect but the next day it stopped working. Now when I pressed memory card on my mobile it says "Not Allowed" or Format giving yes and no. If i press no it goes back to my menu if I press yes it just says Error. I don't understand whats wrong. Is any1 else having the same problem or know how 2 solve it? Tb please x
Also I got An Integral adapter with my phone but when I put tht in the computer the computer cannot find it :S.......I also don't know how to format it either.
yes my card was working fine. i took it out the phone for a bit then put it in again but now its not working. when i try getting in the files its telling me am not allowed.i even try formatting but it failed.
help AR
I have the exact same problem as Jason!!! Help what should I do?
My memory card was working fine a day ago and now when I go to my memory card files it says empty. I tried formatting it but it still won't work
this answer not working
I recently bought a 1GB Transcend Micro SD Card which keeps coming up with a Formatting error. I bought this phone because I want able to listen to my music. Does anyone know how to solve this problem or know of an alternative Micro sd card that will work?
Same problem as jason !
someone plz help
i try to syncronse music onto it from windows media but it isnt the ringt format what do i do?
hey i got a 4gig for my samsung d900 when i puy it into the phone it reads it but if i try opening a file it says not alounf i have formatted it but they is no luck and i was wondering if there is anything else i could do
thanks
i formatted the memory card twice using a different phone, it worked for a while but then the same message comes up saying error.
Hi Im using a axis 1Gb Micro SD Card from my old fone(Nokia 3110 Classic) If I insert it into my otherfone (samsung D600E) it picks up the memory card but when i go into my File manager it only asks me to format my memory card when i say yes it jyst says error. when i connect the fone to my pc with the cable and the fone set on mass storage the computer pics up the memory card but doesnt want to do anything more. i cant format the memory card with my PC either.
Someone Plz help
i tride to format a 2gb micro sd with my rizr but it dosnt even show tha card statuse
my e250d mmc is inserted but not able to be accessed or formatted . An error message is displayed when I try to format it. Nether can I move or save anything on it.
Help me plz: [email protected]
i have a samsung e251 mobile phone withtranscend 1gb miccro sd and it give"not allowed"message on opening itit gives an error message on formatting
Please, help!!!!!!! I have a Kingston Micro SD in Samsung D 600. Whenever i click to open it in the phone, it asks me "FORMAT?" and it does not give me any other option, apart from this question. When I press the same button once again, it says "ERROR". Also it has stopped working when I try to connect to my PC, using the Kingston adapter. It does not appear on the screen, my computer can not read it. I have plenty of videos and pictures and I am not able to open them. Please, tell me how to fix it. Thank you, Monique.
i was using my card with my E250 when it suddenly came up with the word format i pressed yes on the mobile and it read error , can any one explain what i do now, thorogodone
ok, for my e250. i just put more songs and vids on it. i've done this before. i go to open it this time and it comes up with 'format ?' with the options 'yes' and 'no'. a click 'yes' and it come up with 'error !'. how do i fix this?
ok here's whats happening. my card was working fine. i took it out of my phone and put it in the computer using a SanDisk MobileMate Micro Memory Card Reader. it's worked before. i put it in the computer. i put more music and videos on it. as i said before, i have done this before. i take it out of the card reader, put it back in my phone, and it comes up (when i go to open my memory card option) 'format?' with the options 'yes' and 'no'. i click on the option 'yes' and it comes up with 'error!' and takes me back to the menu. i click on the option 'no' and it takes me back to the menu. i've tried formatting it but it doesn't work. i go to memory status and it says its empty. however when i put it back into the computer all my files on my micro SD card come up as if they were there all along. can someone please tell me how to fix this?
i have just bought mi 4gb micro sd card. when i try to access the memory card it sa ys"not allowed!" wat can i do?
my memory card wont format
ok ive tried all of these and they are not working.
can somebody please give me a step by step guide as to how to get this working
thanks in advance
Hi there
When i go to memory card to format it it just says not allowed
I have the gravity phone. I bought a 4GB Toshiba sd card witht he adapter. I have a slot on my dell computer to read and load it. After working on this, trying format after formet, I also went to properties and removed the 'read only' check mark. I also made sure that each file was 'shared'...the computer loaded it fine (I used fat32, thinking it would all work) I went on line and downloaded updated software fro card reader (Vista)...now I loaded the card with several pics, video's and music but after doing this and safely installing the card back into the cell phone (powered off of course)...the phone asked me if I wanted to fprmat...I said no and away I went, back to the menu and repeated the same proceedure a couple more times, even turned phone off, removed sd card, turned back on, then off reinstalled card, then back on...NOTHING !!! Nothing is on the card, the cell phone is telling me this but this is not true because I can play it (the disk) through the access slot...
Anybody have an answer?
my samsang sgh-e250 is restarting ,
I did format my 4GB microSD card using Windows XP and now it says it has zero volume, no disc and errors.
¬¬ i have the same fone Ssmsung E250, it says 'not allowd' n ive tried the formatting thing and doesnt work, but i cant do it on the fone coz i cnt get into it.
Ive just baught an 8gb card n it did it with mi 2gb one, i think its a mp3 tht i put on both, n i dunno wht else to do, help please ^^
