Samsung DV331AEW Dryer Logo
Jason Spivey Posted on Sep 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung DV331AEW/XAA dryer that will not run. i have 240V L-L at the plug. the LCD works as normal, meaning it thinks it is drying clothes. the child lock is not on. the dryer is empty. it does not work in manual mode either. the door switch is good. when i push the play button, i hear two clicks in the control box above the drum. if you are facing the unit, it is on the left side mounted in the top. that is the only thing that happens. the drum belts is good, also. the motor, blower and heating element do not come on. does anyone have any ideas?
  • Dustin Shammo
    Dustin Shammo Dec 16, 2013
    Jason... Did you ever get this resolved? I've got the exact same problem and have checked everything!! I'm thinking of replacing the thermistor, but don't know if that will do it. I also checked the resistance of the motor and it seemed to be within range. Wondering if you have any feedback on what you did to resolve your issue. Thanks!!
  • Dustin Shammo
    Dustin Shammo Dec 19, 2013
    I ultimately found that it was the Thermostat PART NUMBER: DC47-00016A. The switch was good, the cord was good, and I bought a relay switch, but swapped the thermostat fuse first as it tested out with bad results.
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Oct 31, 2013
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146126
Points
960
2 things possible here the belt broke or the thermostat by the thermister opened both scenarios will cause your problem if its the 2nd problem, clean the vent and the drier. inside and out
1 Related Answer
Anonymous
  • 291 Answers
  • Posted on Dec 03, 2010
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
1helpful
2answers
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
Samsung dryer won' shut off dv520aep/xaa
If it's in the timed cycle, the timer motor is probably bad, preventing the timer from advancing through the cycle.
If it's in the auto dry cycle, the moisture sensor could be bad, so the dryer thinks the load is still wet.
2answers
Samsung DV331AEW starts cycle but skips from 44 minutes remaining to 1 minute remaining. How to fix this?
sounds like could be a control board issue? have to check with multi meter suggest you check the timer wire connections on the board looks for burns or seized areas as well as conitnuity
Samsung dv331aew/xaa check filta
You can still operate it while it is drying.There is a bad sensor much like an O2 sensor on a car.
1helpful
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
My Samsung dryer will not power on?
could be a number of things are lights turning on? first check plug for blown fuse if its av3 pin. try swapping for same amp fuse. next check drive belt and after that could be motor or start capacitor.
2answers
Samsung DV331AEW Dryers, Why My Dry it does not have heat?
Did you install the unit? Has the heat ever worked?
DV350AGW/XAA will power on, but does nothing when you push start
i have a bsch was3274 does the same turns on here the relays click 2 or 3 times and water dosent start going in to the machine
1helpful
Drum will not spin.
first disconnect your cord from the dryer, and ohm out the cord. place your test leads to each end of each of the wires. you could have a bad cord. one side of the cord could still give 110 to your board. check to see if the broken belt switch is tripped. if all this checks out, then should be your relay board. the one above the drum.
I have a problem with my samsung dryer. The model number is DV330AEB XAA I have trouble drying sheets. The sheet will always twist up and not dry. I must take it out after 10 min and untwist it then...
THE PROBLEM IS WHEN YOU DRY THE SHEETS WITH OTHER CLOTHING THE SHEETS DON'T HAVE ENOUGH ROOM TO DRY SO THEY TWIST,SO I THINK IS BEST TO DRY THE SHEETS ALONG...
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
