Tilia Foodsaver V835 Vacuum Sealer Logo
tina Posted on Sep 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Foodsaver v3820 will not vacuum the air out. We have cleaned it and out the bag in curling down and still does not vacuum?
Dawn Hamilton Brown
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 02, 2015
Dawn Hamilton Brown
Contributor
Level 1:
Answers
Questions
Helped
1477
Points
Mine is the piston keeps falling off
Brian Mills
Level 3:
Master:
  • Master 613 Answers
  • Posted on Sep 01, 2013
Brian Mills
Master
Level 3:
Master:
Answers
613
Questions
0
Helped
133311
Points
1126
The motor has to be running for it to produce a vacum
5 Related Answers
Anonymous
  • Posted on Nov 21, 2009
SOURCE: My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Steven p buehler
  • 3 Answers
  • Posted on Feb 20, 2010
SOURCE: my foodsaver v2490 will not vaccum the air out the
the problems with vac is allmost allways the gasket or the tubing in the unit there is a few fittings that get britlle over time and the heat in the unit and the china parts dont help i have got a bunch of these broken units on ebay and fix with drip irr fittings
Lee Eismann
  • 88 Answers
  • Posted on Aug 02, 2010
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Ed Mac
  • 731 Answers
  • Posted on Jan 24, 2011
SOURCE: foodsaver V845 is not sealing?
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
My FoodSaver will not activate when I insert a bag. The accessory unit works fine.
It sounds like you are having some issues with your FoodSaver vacuum sealer. Here are a few things you can try to troubleshoot the problem:
  1. Make sure that the FoodSaver is plugged in and turned on.
  2. Check the sealing strip on the vacuum sealer to make sure it is clean and free of debris. A dirty or damaged sealing strip can prevent the vacuum sealer from working properly.
  3. Check the vacuum bag to make sure it is properly positioned in the vacuum sealer. The bag should be inserted with the open end facing the sealing strip.
  4. Make sure that the bag is not too full. Overfilling the bag can prevent the vacuum sealer from working properly.
  5. If the problem persists, you may need to take the FoodSaver to a repair center for further diagnosis and repair.
Sep 21, 2022 • Vacuums
Vacuum doesn't complete before sealing the bag on my FM5330 Food Saver
Odds are it is dirty and the vacuum sensor is plugged. That makes it think the vacuum is complete. So it seals. Check the instructions or a youtube and clean it. You need to use the exact cleaning instructions. Odds are that will fix it.
Foodsaver vac 1050
Perhaps the bags you are using are not suitable. If they are too thin it will not vacuum air out.
3answers
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Foodsaver v3820 does not vacuum
the pump is broken. would you like to repair this? if so let me know so i can give you steps---- assuming you have tried the obvious like ---another power source- toggling the power switch- looking for obstructions. let me know good luck
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Foodsaver wont vacuum v3230
Make sure you put the bag in as it's designed to go in, I s**t you not I tried to use a wider foodsaver bag and cut it down but I inserted it the opposite way than it was intended to go in and it would NOT vacuum the air out. So I cut another bag to test if inserting it the correct way would matter....and it TOTALLY worked fine! Crazy how I couldn't get it to work the other way.
22helpful
4answers
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
4helpful
Top Tilia Kitchen Appliances - Others Experts
john h
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
