I am facing the same issue as you. I have a Skagen 311LTRB watch without a band. I purchased the watch without a band, so I don't even know what the original band looks like.
It seems strange to me that Google doesn't even find that model of Skagen watch when you search on the model number. Makes me wonder if the watch is fake or real.
What I did was purchase an 18 mm mesh band and two pins from the following seller on eBay: "BandFever" / "18mm SILVER MESH WATCH BAND,COMES WITH 2 SPRING BARS".
After installing the band, I am now able to wear the watch. And it feels very comfortable with the mesh band. However, it looks a littly dorky because there are overhangs on each side of the watch where the bands attach. I keep wondering what the watch appeared like when it was new with its original band.
Wish I could paste an image of the watch, but that doesn't seem to be allowed.
SOURCE: Lost screw to secure watch band on Skagen 355LGSC
You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
Find your nearest watchmaker and ask for help.
SOURCE: How to adjust Skagen watch band.
You may have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: Where can I buy a replacement watch band for a
hi..you can buy it from the following place.
http://www.amazon.com/Skagen-Mens-Titanium-Watch-396LTTM/dp/B000ETU7M8
check it out..
thank u..
rate me..
SOURCE: Size watch bracelet
your band is Skagen Signature Mesh
http://www.skagen.com/service/watchInstructions.fx#adjustment
SOURCE: Where can I buy replacement
Try this link:
http://www.skagen.com/service/orderWatchBandParts.fx
