Nokia 7373 Cellular Phone Logo
Posted on Sep 08, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace a broken lcd screen
My 7373 lcd screen is cracked I ordered a new one but dont know how to replace it can you help many thanks
  • 5 more comments
  • blake89 Dec 07, 2007
    hi, my new nokia e65 needs a new replacement screen, can i do it myself or is it best to just pay the fortune to get it professionally fixed?
  • Anonymous Jan 01, 2008
    My boyfriend bought me the nokia 7373 for christmas.i stood on it by accident and now the plastic screen is cracked.i don't know what to do!!!!!!
  • Anonymous Jan 06, 2008
    hi i have a nokia 7373 n i have broken the plastic housing case screen. i have seen housing and tool packs on ebay and wondered if it would be a problem i could fix on my own?
  • Anonymous Mar 25, 2008
    i got my nokia 7373 pink as a present but brother dropped it on the floor and the main screen wont light up.Pleaaase give me any hints on what to do to get the light on again
  • monkeymoo86 May 13, 2008
    my nokia 7373 screen is broken the screen just goes white i can still use the phone.But i cant see anything .What should i t do ?
  • Anonymous Nov 22, 2008
    i have a new nokia e65 the screen got wet and now it dont work everything else works on the phone but the screen stays blank can you help me
  • Anonymous Mar 12, 2014
    We have a blu vivo and the screen is broken, when to several repair shops they said they could not order new screen
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3633
Points
5
See the nokia e65 de-assembly video here.
http://www.youtube.com/watch?v=No2KPrG_QuM
Nicholas Burress
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on Sep 08, 2007
Nicholas Burress
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
19165
Points
128
Its actually not real bad. You will need a plastic pry tool. 1) Swivel the upper assembly so it forms a 90 degree angle. 2) With plastic pry tool go along outside of upper assembly unlocking the clips that hold the front cover in place. 3) Gently remove plastic cover. 4) Gently remove coax connector that connects LCD to board. 5) Release 4 clips that hold the LCD assembly in place and remove LCD assembly(LCD + board + metal frame) 6) Detach the LCD to board connector and remove board from assembly. 7) Release 4 metal clips that hold LCD in metal frame. VOILA! Your LCD is removed. Good luck! Let me know if you need any more help or help reassembling the phone.
cuneas
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 12, 2008
cuneas
Contributor
Level 1:
Answers
Questions
0
Helped
4200
Points
5
I had the same problem, but figured it out.
1) Remove the battery.  Thisis not strictly required, but it is good practice to remove all power sources when changing delicate electronic components
2) You do not need to undo any screws.  Put away your jeweller's screwdriver.  Also, don't remove the protective film from your new screen (yet).
3) Hopefully you've got a prying tool with your screen kit.  If not, use a non-serrated thin bread and butter knife.  Pry off the front cover.  Do this by getting your tool under the long side where it slides against the bottom part.  Push the edge of your tool in almost vertically - so you almost scrape the inside edge of the front cover.  Gently lever it off the top chassis.  What you are removing is the entire front - all the dark plastic and the metal around the screen as one unit.  Once you have one side off, it should come away.  The keyboard will fall out - that's normal.
4) Remove the dark plastic/rubber component at the top of the screen.  Do this bygetting your tool under its bottom edge and simply levering it off.
5) Remove the old screen.  Do this by releasing the clips at the tops and bottom of the long edge.  Remove the screen and the clipping assembly (thin and flimsy metal frame with four tiny clips) together.  Remove the plug by just pulling it out of the socket (top left of screen)
6) Note where the clipping assembly is stuck to the screen. Remove the clipping assembly by peeling it off the back of the old screen.  Stick it to the new screen - the adhesive will be good for the second screen as long as you don't touch the sticky surface with your fingers.
7) Install the new screen by pushing it into place so the four clips lock into the chassis.  Push the plug into the socket.
8) Re fit the plastic/rubber part. Now you can remove the protective film from your new screen
9) Place the keyboard in the right place: there are two little locator pins - place the keyboard so they fit into the little sockets.  Push the cover back on.  You might not be done yet - read on.
10) Restart your phone.  If everything seems OK, you're done, but if you're like many people, your phone's screen will now be continuously flashing on and off every couple of seconds.  DON'T PANIC!  What you need to do is upgrade your phone's firmware.  Do this by going to www.nokia.com and following the links to upgrade your firmware/software.  You'll need your USB cable.
Good luck.  It worked for me - just be patient and take your time.
  • cuneas Dec 12, 2008
    I should have added - THIS IS FOR THE E65!
boy007
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 29, 2010
boy007
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5814
Points
6
You will find replacement screens,
tools,... ext. to make repairs your self
from below link.
http://sites.google.com/site/citizenbetterbusiness/home/nokia
Also it's said that better to buy better
phone, Nokia's have prone problem whit
LCD-SCREEN's that break at normal use.
A
Anonymous
Any pictures please
1helpful
Replaced cracked screen and seen LCD has slight crack,but phone worked perfectly before I put new screen on.Black screen now,and nothing shows up.Can anyone help please !
You need to change it again, because some screen and lcd are not function perfectly, maybe the flix of the lcd has a damage or a broken connection, because some supplier are still selling it,even that they know are defected
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
My screen has cracked and i dont know how to replace it
Here you go :)
http://www.youtube.com/watch?v=7JkDBptpquc&feature=related
1helpful
man this is the best i fixed my lcd in les than 2mins ..fantastic
Cracked screen
If its just the glass/plastic then just buy a new fascia
If its the LCD screen - go to www.foneunlockers.com you can get lcd screen then go onto youtube "How to repaif LCD ScreenNokia 7373" explains how to do it x
Apr 21, 2008 • Cell Phones
My mobile phone wich is a nokia 7373 has cracked. its only the screen not the lcd please could you help me on to how i could fix this thanks suzanne
LCD change on 7373
  1. Switch off the phone.
  2. Take SIM card out.
  3. Take front faceplate off by inserting Credit card/Tweezers between housing and silver key. As you pull up, take credit card and slide it on the side of the phone prying the clips off. (Gently tease it out working around the phone)
  4. Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen. Slip the little black frame off of the LCD screen, and lift the screen. (Prize it up gently from the swivel end of the mob.) There’s a printed circuit board underneath it is attached to the LCD by a hook type catch. Don’t damage it (the board). You should now see a screw. Removing this screw removes the back cover.
  5. That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
  6. You should use anti static gloves for this job, avoid touching the connections and the LCD face.
See it done on http://www.youtube.com/watch?v=7JkDBptpquc
"Confucius he say: Man with one chopstick, go hungry."
Replacement cover
This might help, also do a search on YouTube for Nokia 7373.
LCD change on 7373
  4. Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen. Slip the little black frame off of the LCD screen, and lift the screen. (Prize it up gently from the swivel end of the mob.) There's a printed circuit board underneath it is attached to the LCD by a hook type catch. Don't damage it (the board). You should now see a screw. Removing this screw removes the back cover.
3answers
Cracked LCD Screen, please help
Ebay...buy one that says "please connect to Pc"...use the screen that says that. Done deal
5answers
Screen cracked
pleace change the total sceen.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
