SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry [email protected]
SOURCE: we have a small magic chef used for sodas, etc.
Magic Chef MCBR1010W 10 Cu. Ft. Refrigerator
Good Luck and Please rate FixYa!
also here is manual
http://www.retrevo.com/support/Magic-Chef-MCBR1010W-Refrigerators-manual/id/6360bh648/t/2/
SOURCE: Defrost timer might not be working
The timer is located behind the fridge , down by the compressor .
SOURCE: have a magic chef refrig
in the bottom back of the fridge, there is a black box (3"x3") with a little white plastic screw type thing in the center. turn it slightly to see if the fridge starts up. Mine is doing the same thing, making it untrustworthy as it shuts off at will. I am currently looking for the replacement part.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
