Haven't used this safe in about 6 months and battery appears to be dead. Also can't find instruction booklet. Have key and know combination. How can I get in with dead battery?
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Thank you, scsmi48081!!! You were Spot-On!!! Had my S5741 Sentry within 30 secs!!!
I meant to say that I had my Sentry S5741 Fire Proof Safe "opened" within 30 secs, thanks to your post, scsmi48081! Thank you!!!
Thank you SO much!
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Our safe had a philips screw at the bottom of the keypad (facing downward), not a paperclip hole as some do. To replace batteries, unscrew this setscrew and twist the face gently. Replace the 4AAs and reinstall faceplate/fingerpad. Should work.
I have dead batteries too, and my safe won\'t open. On top of that, one of the wires is dangling. So when I touch the dangling wire to the battery pack (fresh Batteries), it says low batteries and put the key and turn the knob. STILL WON"T OPEN!! So sad, need help. Never thought this would happen, wonder if anyone can help?
Sentry safe model so500, dead batteries, can't open it. Help!!
have keys and code changed batteries but ligths will not light
