Crosman 1377 177 Single Shot Air Pistol Logo
Anonymous Posted on Aug 09, 2013
My crosman 1377 wont hold air in the resivwar and ni matter how much i pump it, it never fills with air. i use 3 drops of oil weekly or after i use it a ton. help!!!!!
2 Related Answers
Anonymous
  • 10319 Answers
  • Posted on Jun 07, 2010
SOURCE: My crosman 1377 won't pump up. Is there a
The pumps seal is bad so take it apart and cut a piece of leather out to fit
Coat the leather with Vaseline and it will operate just fine for you
Anonymous
  • Posted on Apr 11, 2011
SOURCE: Older Crosman 1377 Air Pistol. Believed to be bad
Yes. This is as simple as replacing O-rings and seal bushings. you may get out for less than $5 worth of supplies. Just be sure to label everything as you take it out of the gun and lay out the parts in the order you removed them. this will make reassembly MUCH less painful. Oh yeah.... remember to clean and oil the parts as you put them back in.
Testimonial: "Very helpful. Will now try to do it. "
Crosman 1377 single shot pellet air pistol-how do i remove pellet from barrell?
if you dont have a cleaning rod for it you can go to your local bass pro/cabelas/outdoors store and get a cleaning rod for a .17 caliber for fairly cheap. you should be able to push the pellet out or clean it if there is dirt or grime in it. and make sure you use the right caliber pellet! (:
I have a crossman 1377 (177) cal pellet pistol. Is it ok to shoot BB'S in this gun? Does it damage the rifling in the barrel? Thanks, Gary
yes it safe to shoot bb,s in the 1377 pump pistol,i have 3 of them they actually shoot true'er and with more vilocity
2helpful
Older Crosman 1377 Air Pistol. Believed to be bad seals. I'm told I can buys the seals from plumbing supply store and fix is easy to do myself with no experience. True?
5helpful
Pistol will not pump up
Sounds like the O-ring inside the pump mechanism is bad or going bad. You can try to add a little lubricating oil and see if that can stop the O-ring from leaking.
Hope that helps!
Please don't forget to rate.
15helpful
2answers
My crosman 1377 won't pump up. Is there a replacement part available for this problem?
2helpful
Crosman 766 wont hold air areadly oiled the seal
Try raising the pump lever and douse the inside with Barricade or Remington spray oil, then slowly pump it halfway or until you hear the air loss, do this several times or "rinse and repeat" until it keeps it's seal. Another good idea is to do this every couple months, leak or not!
3helpful
3answers
Crosman 140 pump rod adjustment
Contact Alan at ABairgun.
I own a Crosman 140 (c. 1962). The nut should be tight.
Richard - in Virginia
Crosman 1377 air pistol
the seal must be broken. send it back to whom you bought it from and get an exchange
Top Crosman Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Crosman Cycling Expert? Answer questions, earn points and help others
