20 Most Recent Crosman 1377 177 Single Shot Air Pistol Questions & Answers
bought a gun with a bent barrel
so bent that the sights cannot be aligned to get to right
Crosman 1377 177... | Answered on Mar 24, 2017
if you dont have a cleaning rod for it you can go to your local bass pro/cabelas/outdoors store and get a cleaning rod for a .17 caliber for fairly cheap. you should be able to push the pellet out or clean it if there is dirt or grime in it. and make sure you use the right caliber pellet! (:
Crosman 1377 177... | Answered on Aug 09, 2013
yes it safe to shoot bb,s in the 1377 pump pistol,i have 3 of them they actually shoot true'er and with more vilocity
Crosman 1377 177... | Answered on Jan 05, 2012
Sounds like the O-ring inside the pump mechanism is bad or going bad. You can try to add a little lubricating oil and see if that can stop the O-ring from leaking.
Hope that helps!
Please don't forget to rate.
Crosman 1377 177... | Answered on Dec 23, 2011
Hi orichtero...
Take the air gun to the nearest roller bearing seller, they will have o rings also...they will be able to fit the right o ring for your gun for you
Please take time to rate me
Crosman 1377 177... | Answered on Aug 12, 2011
Yes. This is as simple as replacing O-rings and seal bushings. you may get out for less than $5 worth of supplies. Just be sure to label everything as you take it out of the gun and lay out the parts in the order you removed them. this will make reassembly MUCH less painful. Oh yeah.... remember to clean and oil the parts as you put them back in.
Crosman 1377 177... | Answered on Apr 11, 2011
Unfortunately, there are no parts available for your Benjamin Sheridan Air Pump Pistol that I know off. But I would suggest you contact the manufacture of this pistol via e-mail or phone and ask them if there actually parts for this pistol. They might have the parts or send you to a deal where the parts can be gotten (if available).
I think the manufacturer is the best to contact as they might be of help.
Good luck.
Crosman 1377 177... | Answered on Dec 20, 2010
Crosman 1377 177 Single Shot Air Pistol Logo
43 questions posted
Top Crosman Cycling Experts
Marvin
Marvin
Michial Gueffroy
John Egan
John Egan
Are you a Crosman Cycling Expert? Answer questions, earn points and help others
View Most Popular
Crosman Cycling
  • Crosman Cycling
Most Popular Question
older crosman 1377 air pistol believed
  • Cycling
