I have a galaxy s3 when i wanted to download a video using the built in browser i click on the video and two choices appear either video player or internet when i click on internet it starts downloading But now when i choose internet (to download the video) a massage pops up saying "Unfortunately, the process com.android.browser has stopped" What can i do? Please help :)
SOURCE: i get a force close message on my phone. what do i
This basically means the OS is having severe problems. You need to try a master reset first. If this does not work and there is no software update available from the HTC website you need a replacement handset.
SOURCE: I keep getting an error
Try this.
settings>applications>Manage applications>(select the "ALL" tab)>select "Market"
then "Clear data"
Download the latest market .apk file from
thegadgets.net, make sure you keep it in the root directory of SD card.
Once downloaded, install the market app with the help of apkinstaller
If still the problem persist hard reset your phone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: My touch screen will not
brother open your phone if you can and reinstall the parts of re-heat it there are parts of it that are lost contact to the other parts or you can just go to a nearest service center in your area
SOURCE: The process com.android phone has
I would start with a Master Reset. That's the best place to start.
Pulling the battery doesn't really do anything but fix little problems.
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
SOURCE: I have HTC smart f3188
go to your market and download youtube its free and you should be able to run videos
