SOURCE: jenn-air svd48600w model. End caps
Try these 3 websites below
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=488456&ST=PBM
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43495
http://www.partselect.com/MultiModels.aspx?ModelNum=SVD48600W&searchTerm=&RefineSearch=0
SOURCE: How do you change a
Hello, click this link it is the schematic for the surface burner assembly to your unit http://c.searspartsdirect.com/lis_png/PLDM/M0703087-00001.png actually here is the link to your entire units schematic which would be easier for you if you had the entire link click this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Range-Parts/Model-PRG3610NP/1266/0124002?searchedModel=PRG3610&blt=06 . I have had to perform this for similar machines such as Ge monogram, thermador, and viking as well which are built very similar. If you first remove part labeled 3 and 4 and then carefully unscrew 5 I have had the fun task of having to replace what is labeled as 19 and its not fun. click this link http://c.searspartsdirect.com/lis_png/PLDM/M0703087-00003.png you may have to unscrew also the front panel and then unscrew part 2 from parrt 1 so that you are able to lift to get your hands in to replace the electrode 6 is the one on the burner diagram that has to be lifted in order to get at the electrode. If you have any further questions message me back. I await your reply Thanks
Rick
SOURCE: How do you remove front panel on jenn-air sve47100
Make sure to dsc stove or be careful ... Open the oven door and look under the panel, tools that you will need are phillips screw driver and a 5 sided bolt head tool .... there's 5 screws and 2 of the other tool.
