To rewire a Delta AP 400 Dust Collector to 220 Volts, you will need to obtain the right wiring and circuit connectors. You may need to consult an electrician or technician to complete the job safely.
There is likely a nameplate with a wiring diagram inside. Without being familiar with the specific model, I can't tell you where. If you can find it, it will show both 460 and 230 volt configurations. Regardless, you will find inside the wiring box (where the conduit comes into the mixer) there are four wires corresponding to two windings - for 460 volts, the windings are wired in series. For 230 volts, they should be wired in parallel.
You have to get you a transformer .voltage input 120 and out put 24 volts.But will have to wire it through a relay or contacter with the coil volts 24.
