Everytime I start my player it says
internetal memory unknown format attach USB and reformat
I cannot figure out how to fix it even with the instructions that came with my player.
Yous should try reformating the player using Motorola's firmware. (Go to http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio
and download firmware v1.11 .) I've also found that calling Motorola's help line was useful.
Likely not new but worth the try. Had reviewed various other POSTS, and suggestion to take out battery and let sit for a while. Often cures unknown ills. Took out the new battery that did not work, let it sit overnight, put battery in again next morning and it booted up. This was done after, changing three batteries, after taking in/out the SD card (no real reason, but figured why not) and, after a subtle BANG on each of the corners of the unit......
Hello Mr . You Can Download Free MP3 From Youtube By This Site : video2mp3.net If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Press the MENU and turn it on, as soon as the word RIO shows on the
screen release the power button but do not release the MENU
button until it says upgrading Plug the USB cord to it and install Rio Forge Firmware_120 Turn the mp3 off then on normally Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
This process worked for my m25:
1. Download v1.11 firmware file from http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio
2. With USB cable disconnected, turn off the m25.
3. Press Power while holding Menu button until UPGRADE is shown.
4. Connect m25 via USB cable.
5. Run the firmware downloaded in step 1.
6. Disconnect the USB cable, and the m25 should start a normal.
