20 Most Recent Motorola Mobility M25 MP3 Player Questions & Answers
The m25 will not power on if LOCK/UNLOCK is in the locked position. If you press the POWER button, a padlock will appear on the LCD to remind you that the unit is locked. Confirm that the LOCK/UNLOCK switch is not in the locked position and press POWER to turn it on. If nothing happens after pressing the POWER button, the battery is probably discharged.
Motorola... | Answered on Aug 02, 2012
Connect the player to the PC and scan the files within. If there is any virus/malware detected please remove all files and clear the memory.
Now reload with safe files and to only about 85% of the memory space of the player.
If there is a reset please also reset the player after loading with new files.
Motorola... | Answered on Oct 06, 2011
Likely not new but worth the try. Had reviewed various other POSTS, and suggestion to take out battery and let sit for a while. Often cures unknown ills. Took out the new battery that did not work, let it sit overnight, put battery in again next morning and it booted up. This was done after, changing three batteries, after taking in/out the SD card (no real reason, but figured why not) and, after a subtle BANG on each of the corners of the unit......
I've had a 1gb sd car for two years or so and never had any trouble. I'd like to hear the answer on the question whether 2gb cards work, too, though.
Motorola... | Answered on Apr 23, 2011
MP3 players need the music files converted to mp3 file format before copying to your MP3 player.
1st - You need to convert your CDs to MP3 musicfiles.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
There are also Freeware CD RIP programs on the Internet that add the musictitle and album title to the mp3 file automatically.
OR
Download MP3 music files from the Internet to your computer, some sites willcost money to download these music files.
2nd - connect your MP3 player to your computer using the supplied USB cable.The computer will see this player as an external storage device, Just copy theMP3 music files from the computer's hard disk to the MP3 player. I suggest you create a album/title folder for eachCD so you can place the MP3 music files by that artist into that folder. Thencopy these folders to your MP3 player and you will be able to select and playyour MP3 music by selecting the album you wish to play.
NOTE - When the USB cable is connected to the computer, it will also charge theMP3 player's battery.
Motorola... | Answered on Dec 22, 2010
Hello Mr .
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Motorola... | Answered on Aug 29, 2010
I think that the M25 only supports 1GB memory cards. (I've never tried a larger one in mine) Motorola's website only says up to 1GB.
Motorola... | Answered on Oct 08, 2009
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio
Will get you the current firmware v.1.11
Motorola... | Answered on May 08, 2009
i removed the sd slot with a screwdriver then i put it on again, worked for me
Motorola... | Answered on Dec 24, 2008
Don't change the battery, but you have to take the battery out and leave it out for 2+ hours. Then put in a fresh battery and you are good to go. Mine does this every month or so. There is something about having no battery in it for a while that tells it to do something that cures this. Weird but I've been doing it for years.
Motorola... | Answered on Sep 18, 2008
This process worked for my m25:
1. Download v1.11 firmware file from http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio
2. With USB cable disconnected, turn off the m25.
3. Press Power while holding Menu button until UPGRADE is shown.
4. Connect m25 via USB cable.
5. Run the firmware downloaded in step 1.
6. Disconnect the USB cable, and the m25 should start a normal.
Motorola... | Answered on Sep 03, 2008
tengo un problema con el reprductor
Motorola... | Answered on Aug 15, 2008
Are you trying to delete the sony via the motorola music manager software and it does not delete???
Motorola... | Answered on May 20, 2008
In order to delete the unwanted songs from your device, you must launch the Motorola Digital Music Center - it should have come with the installation CD, but is also available on Motorola's website at:
http://broadband.motorola.com/consumers/support/default.asp?SupportSection=DigitalAudio
under Motorola Music Manager
When the M25 is conected to the computer and the music manager is launched, you can view a list of all songs on the device by clicking on the icon of the M25 in the left-hand side of the window. You can highlight the songs you don't want by left-clicking the song and pressing delete on your keyboard. There will be a prompt warnign you that this will delete the selected songs permanently from the device.
-Tha Mp3 Doctor
Motorola... | Answered on Feb 04, 2008
Did you change the battery?
Did you drop it in the water?
Motorola... | Answered on Dec 30, 2007
Try reformatting the memory while it is connected to the PC.
Motorola... | Answered on Dec 09, 2007
Yous should try reformating the player using Motorola's firmware. (Go to http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio and download firmware v1.11 .) I've also found that calling Motorola's help line was useful.
Motorola... | Answered on Sep 25, 2007
Believe it or not, to reset the unit you need to remove the battery for a couple of hours. I had the same problem and this solution worked for me. Good luck!
Motorola... | Answered on Jan 07, 2007
Motorola Mobility M25 MP3 Player Logo
30 questions posted
Top Motorola Mobility Audio Players & Recorders Experts
ka4iup
ka4iup
john h
Andrew Taylor
Andrew Taylor
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Audio Players & Recorders
Most Popular Question
internal memory
  • Audio Players & Recorders
