The low voltage light would indicate that there is not enough power reaching the amplifier through the power wire. Are you using 4awg or bigger wire? Is the amp grounded well? Does this happen all the time or just at high volume?
Try checking your power and ground connections and ensure that you are using the correct size of wire.
Dell Inspiron 1000 PC Notebook proplem
Now, if you forget your password, first prepare Windows Vista installation CD, then the computer will enter BIOS first startup Settings for cd-rom start. When the screen, click start presentation by any key cd-rom start system. Then when the interface language appears in the "next", click on the installation interface click "repair the computer ", the "system in the popup window list", click options repair" prompt ".
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet. Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
Maybe there are some problem in your start button (the button wire connect to mainboard is Loosening.
Please press the start button for about 3-4 seconds then see it would start. Always it may solve the problem, this happend to my inspiron 6400 too, after used for years the start button failure. It shows only power lamp lights green but the other light cant light red.
If no, maybe your must change a power supply, as the lower volt current cant start all the device.
