i have 8 usb ports on my pc, but when i plug in my usb 2.0 flash drive, pop-up notice says" this device can perform faster if plugged to a usb 2.0 port", as i looked at the device manager, it has an enhanced usb port diver installed, so, which of the 8 ports is a usb 2.0? are my ports usb 1.0?
my pc has usb ports, i dont know if it is usb 1.0 or 2.0, how to determine what my port?
You can't post conmments that contain an email address.
USB 1.1 allowed a maximum transfer rate of 12Mbits/second. USB mice and keyboards need only 1.5Mbits/s to function. That performance level is also named 'USB'.
USB 2.0 has a raw data rate at 480Mbps, and it is rated 40 times faster than its predecessor interface, USB 1.1, which tops at 12Mbps. Originally, USB 2.0 was intended to go only as fast as 240Mbps, but then, USB 2.0 Promoter Group increased the speed to 480Mbps in October 1999.
You can use USB device with USB 1.0, USB 1.1 and USB 2.0 as long as your PC or laptop has USB ports, but USB 2.0 device transfer data at 480 Mbps on systems with USB 2.0 support only.
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
If you PC does not see the drive (assuming the PC has all the required USB drivers), then, 1 check and or subsitute the USB cable. 2. check the power supply/wall wart for correct power. 3. check the USB plug on the PC, try a different one if equiped. 4. the USB interface card in the external case may be toast. You will need to check or sub the interface to ensure that's not the issue. 5. place the drive in a different case with a different USB interface.
1. Try a different USB port. If other ports recognize it, then the original port is fried.
2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
There are few possibilities.
1. You device is broken
2. You usb port is broken
3. Your device was previously installed on different port and now windows cant recognize it on this port.
Solution:
Try to plug in your device to different usb slot.
Try different USB outlets on your computer. Try it on different computers too. Then if still nothing.....it's fried! I hope the warranty is still valid if it is! Most companies will do a 1 for 1 replacement on flash drives.
1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
What type of keyboard you are using (PS/2 or USB)? Is that a regular keyboard or multimedia keyboard? You need to isolate the problem. Please follow the steps below.
If you are using a USB keyboard:
1. Connect the keyboard into different USB ports of the computer. 2. Connect the keyboard into different computer. 3. Try using different keyboard to see if the problem will persist.
If that is a wireless keyboard:
1. Try replacing the battery 2. Connect the receiver into different USB ports.
Check the keyboard settings:
1. Go to the Control Panel > Keyboard 2. Adjust the keyboard settings and speed.
