I bought a Bose Solo TV Sound System. I want connected with my TV. I subscribe to Bell Fibe. I connected the wire coaxial digital audio from TV to Bose System, but there is no sound. What is the problem?
? 2:12
https://www.youtube.com/watch?v=QQziZ3w6z0A
Jun 22, 2015 - Uploaded by Lisa Tiffany Knowles
Learn To Bose Solo TV Sound System Review Read More reviews from Amazon Buyer: ... I received this sound system withno knowledge of what it really is. ... The rep that I worked with (they assign you one person to talk to--a real. live person who emails you ... bose solo tv sound system universal remote
Bose CorporationThe Solo 15 and Solo 10 series II systems dramatically improve television sound. ...Follow these steps to program your Bose® universal remote to control the other ... high quality home theater sound from your Bose system, you should turn off
Bose CorporationDiscover product support for your Bose® Solo TV sound system. ... Learn about using existing universal remote controls with your Bose system. more » ...
Bose CorporationSolo. TV Sound System. Owner's Guide ' Brugervejledning ' Bedienungsanleitung ' ...10. Step 5: Plug the other end of the audio cable into your TV ......................
Contact the authorized service center for Bose. The fault is with its audio output amplifier section circuit. Normally, it will be difficult to get spare parts to this set at local electronic spare part market. Gopakumar Gopalan Google
REad the instructions carefully. Take the uni back to where you bought it and have the salespeople explain how it's used. Call tech support for Bose on their toll free number.
I have had this happen several times now. Unplug the Bose power plug for a few minutes, then plug the power back in and turn the Bose back on. It has reset the Bose unit everytime and the audio is back.
At the back of the Bose Solo are three different audio inputs. Optical digital-IN, coaxial digital-IN and Cinch (RCA) (white and red) analog audio-IN. You should check if your TV has an optical digital-OUT, coaxial digital-OUT or an Cinch analog-OUT connection. you need at least one of these three connections. If not, there is no possibility to connect your Bose Solo to your TV. If you use a SETOP-box to watch TV, you could check if it has one of these audio outputs. If it has, you can connect your Bose Solo the your SETOP-box.
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you he speakers are not connected properly.
Check the speaker connections.
The sound level on the rear or center speakers is turned down.
Adjust the sound levels.
The receiver is not in the proper surround mode.
Set the receiver to a surround mode.
The speaker settings are incorrect.
Check the settings as per the user's manual.
sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide)
1. Hold down the aux button until all lights flash.
2. Press 2 to ensure Aux is set to audio.
3.Enter code 761 and press the pound (#) button.
Now to have the satellite remote default volume to Bose Solo do the following.
1.Press and hold AUX
2.press # pound
3. Press the + side of volume
4. Press 0
5. Press pound ( AUX button will flash 3 times)
6. Press SAT mode
7. Test the volume on Bose Solo.
(see page 22 of Bell 9242 guide)
