Sentry Fireproof Safe Logo
Posted on Aug 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sentry safe V530
I have lost the combination to my safe. It uses a key and combination. Door opens and has a shelf. Thanks
  • Anonymous Mar 22, 2014
    safe wont open using keypad
  • Anonymous Apr 01, 2014
    lost combination to my Sentry Safe. Serial # 811702
Anonymous
Level 2:
  • Expert 78 Answers
  • Posted on Aug 28, 2007
Anonymous
Expert
Level 2:
Answers
78
Questions
0
Helped
26740
Points
190
Follow this link to the usermanual. On page 3 there is a guide to re-setting the code. http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
2answers
Sentry Supreme 5330 safe will not open
If your Sentry Supreme 5330 safe is not opening, there could be a few possible reasons why:
  1. Combination Error: If you are using a combination to open the safe, make sure that you are entering the correct combination. If you have forgotten the combination, you will need to contact Sentry Safe customer service to get assistance on how to recover or reset your combination.
  2. Dead Batteries: If you have an electronic lock on your safe, the batteries may be dead. Replace the batteries and try again.
  3. Jammed Bolts: The locking bolts may be jammed due to incorrect operation or a mechanical problem. Try tapping the safe door gently with a rubber mallet to loosen the bolts and then try to open it.
  4. Mechanical Malfunction: If the safe still does not open, there may be a mechanical malfunction. In this case, you will need to contact a professional safe technician to diagnose and repair the problem.
Note: If you have lost your key, you will need to contact Sentry Safe customer service to order a replacement key.
Sentry Safe 1250. How to change the combination please?
Safes with dials are a little more complicated. NEVER close the door after changing the combination. Practice the opening sequence with the door open. If you did it wrong, you can reset and try again
https://www.google.com/search?q=Sentry+Safe+1250.+change+the+combination
Sentry safe 1250 lost combination
I have a sentry safe 1250 .83 cubic and I have the key I was using the safe for awhile without the combination and just the key but now the key wont work and someone messed with the combination part which I dont know the combination i dont know what to do and I dont wanna trash this safe
Lost keys
A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. But only a small supply in stock.
4helpful
2answers
How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
1helpful
Lost combo sentry v530
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
1helpful
2answers
Sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
1helpful
2answers
Sentry safe
u can request a lost combo from the sentrysafe.com u gotta get a it noteiatized and send it in to them the details are listed on the webpage i hope this helps u
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
