If you have forgotten your pass code, and if you have to remove it to sign into Xbox LIVE, follow these steps:
Note The following steps apply only to Xbox LIVE online profiles. When you delete an offline profile, you lose any Gamerscore that is associated with the profile. You also lose achievements and statistics that are associated with the profile.
Delete the profile for which you forgot the pass code. To delete a profile, follow these steps:
Go to the Settings hub and select System.
Select Storage.
Select the memory device on which your profile is stored.
Select Gamer Profiles.
Select the profile that you want to delete.
Select Delete. When you are prompted, select Delete Profile Only.
Press the Guide button and select Download Profile.
Follow on-screen instructions to download your Xbox LIVE profile.
If you want to set the pass code again, follow the steps to set an Xbox LIVE pass code.
Go to My Xbox>System Settings>Memory on your xbox dashboard. Delete your profile only (not profile and games) from the hard drive and then recover it to the console. To recover your gamertag to your console, all you need is the email address and password associated with the account.
You'll need to use recovery game tag, and verify your status with MSN Microsoft, Think about changing your password, could your profile is being used at a friends house, maybe add a pass code to your profile.
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to
control access to features and options. Because Family Settings exist
for both the console and for Xbox LIVE accounts, you can set pass codes
for both. Here you can learn how to:
Set an Xbox LIVE Pass Code When
you set an Xbox LIVE pass code for your profile, anyone who wants to
use that profile will need to enter the pass code before signing in to
Xbox LIVE. To set an Xbox LIVE pass code:
Go to My Xbox and open your profile.
Select Manage Account, Xbox LIVE Pass Code.
Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You
will have to enter your original Xbox LIVE pass code before you can
create a new one.)
Set a Family Settings Pass Code When
you create a Family Settings pass code, anyone who wants to change
family settings on your console will need to enter the pass code first. You can also use your Family Settings pass code to override game
and movie settings if you (or those with whom you share your pass code)
want to play games or watch DVD movies that your console settings
normally block. For example, you could give the pass code to your 18-year-old so
that she can watch R-rated movies that your younger child is not allowed
to see. To set a pass code for your console:
Go to My Xbox and open System Settings.
Select Family Settings, Console Controls.
Select Set Pass Code.
Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
Choose a pass code reset question.
Select Pass Code Reset Answer and enter
your answer using either your Xbox 360 controller or a standard USB
computer keyboard plugged into a controller port on your console.
Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
To reset your pass code, repeat this procedure at any time. Reset a Forgotten Pass Code To reset your pass code after you've forgotten it:
Enter an incorrect pass code.
You'll be told that your pass code is incorrect. SelectReset pass code.
You'll then be shown your pass code question and asked to answer it.
Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as
well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX
(1-800-469-9269).
Its not a big problem as long as you have a recovery question set up with the account.
Try going to http://msn.com and trying to recover a password with the email you provided.
If not, you just have to try and remember it.
profile.
In the My Xbox area, select System Settings.
Select Memory.
In the Xbox LIVE section of the Xbox Dashboard, select Recover Gamertag from Xbox Live.
Select Yes when you receive the following message:
To join Xbox LIVE, you must exit your current session.
Enter the gamertag for which you want to remove the pass code, and then select Done.
Select Next.
In the E-mail Address
section, type the Windows Live ID credentials (the e-mail address and
password that you use to sign in to the Windows Live ID) that are
associated with your gamertag, and then select Done.
Enter the password for the Windows Live ID account, and then select Done.
Select Sign In.
your windows live id is your email address your pass word is your pass word to your email address if you forgot those you can go on your computer and change your password to your email then give it 24 hours to kick in and then try it it should work fine if you have anymore questions go to my profile and email me.(you help me when i help you) thank you
You may very well have a bug in one of your saved files/downloads. To fix this issue, what you will need to do, is delete your gamertag, basically to refresh your xbox HDD, then go to xbox live and go to RECOVER GAAMERTAG,place the email address you used to originally set it up, and recover it. this HAS happened to me once before, and this has a 99.99% of working, now before you start worring, you will not lose your gamertag altogether,....unless you forgot your email address. Let me know how this goes, thannks justin Please rate me
