For the dual tuner, if you are unsure what this is... please look at the back of the satellite box and see if you have 2 sat in cables. if you do, then you need to reprogram your satellite. if you do not have 2 sat in cables then you would need to contact dtv to get this installed.
Yes.. You have to have a dual tuner. If you do, make sure it is in dual mode. Usually a light on the front of the box will indicate this. Otherwise, you have a single tuner and hence cannot watch one channel and record another. Call DirecTV and tell to send you a dual tuner DVR or Two Room DVR. With this you can tell it to record on one TV while you watch another.
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
SOURCE: Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
