Amperage draw is listed as 4.8 amps for the 5000 BTU room AC. I would like to run this unit off of a Honda 1000 watt generator. The above requires at most 600'watts to run, after the ingress current gets it operational. What might the ingress current be? Another way of asking the question is ," what is the surge wattage"? The Honda runs continuously at 900 watts. Thank you.
You are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
SOURCE: model 6994f230600325 watts required to run and to
To find the wattage of the unit running, multiply the voltage (220?) by the amp draw (marked on unit) The problem I am seeing is the initial amp draw is prob. going to be close to 60 amps, and I am not sure if your generator is capable of this. Hope this helps
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
