20 Most Recent Watts Onan Portable Generator - 5000 , Model# 6500 Questions & Answers
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
Watts Onan... | Answered on Dec 28, 2018
12 V going to the pump, but is it turning (do you hear it running). If not change it.
Watts Onan... | Answered on Feb 12, 2015
You have voltage,but not Amps.Voltage plus Amps = Power
Charge the Battery .
No amps, low power,its why makes only clicking sounds.
Watts Onan... | Answered on Sep 03, 2014
I don't understand your question. Are you asking if 147 VOLTS is too much at the receptacle? If so, yes - that's too much. Are you asking if 147 amps is too much to expect from your generator? If so, yes, that's far too much.
Watts Onan... | Answered on Jul 27, 2014
There are many possible reasons from stator output voltage to sensing, to fuel to control boards. A good place to start (as the unit does run) would be with the fuel system, if it has sat a long time it won't help. Also the fuel filter. try conencting to an external fuel tank versus the vehicles, as sometimes pick up tubes in main tanks can be an issue. Also check the correct oil level and viscosity / and oil pressure switch. Failing that I recommend a service center, as there really are so many causes, I cannot list all on here.
Watts Onan... | Answered on Nov 16, 2013
This generator has a built in transfer switch. If you do not have an external source of 240 volts going in to the unit (utility power), the transfer switch will show a fault or "abnormal" reading. If you do have utility power going in to the transfer switch, and the generator is on then you have a faulty transfer switch. It is time to warranty or get a replacement switch.
Watts Onan... | Answered on Oct 18, 2013
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
121 questions posted
Top Watts Electrical Supplies Experts
Sheldon Dedek
rlev_7
Level 1 Expert
Norman Worley
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Watts Electrical Supplies
Most Popular Question
onan generator emerald iii genset push
  • Electrical Supplies
