The Pioneer dvd-rw referenced above in my notebook (aspire 5630) does not function - code 39 error. The driver is the problem but I cannot find a new or updated driver to make it work. Can you help?
Pioneer DVR-K17RS ATA in new laptop - suddenly stopped working - gives code 39 error; can't reinstall driver. have tried deleting it from devices (Windows vista machine) Sorry the product is an Acer Aspire 5720 but this programme refuses to accept that
pioneer dvd-rw just stopped working has dvr-k17rs driver
Acer Aspire 5610--same problem--all of a sudden stopped working. Can't find driver
The same problem with an ACER 5635. When I use burning software the device is not detected. I`ve emailed Pioneer and Acer and waiting for a solution.
same problem
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Actually there are here no problems and the driver here not and the matter is that 98 % of users think that it is the driver but it not so, is simple if you have established Itunes from Aplle remove it and all will earn as before. Good luck to you also do not puzzle about it. This problem meets on Aspire 5235
Aspire 5310
Aspire 5315
Aspire 5320
Aspire 5330
Aspire 5335
Aspire 5338
Aspire 5410
Aspire 5500
Aspire 5500Z
Aspire 5510
Aspire 5515
Aspire 5516
Aspire 5520
Aspire 5520G
Aspire 5530
Aspire 5530G
Aspire 5535
Aspire 5536
Aspire 5536G
Aspire 5538
Aspire 5538G
Aspire 5540
Aspire 5550
Aspire 5560
Aspire 5570
Aspire 5570Z
Aspire 5580
Aspire 5590
Aspire 5600
Aspire 5610
Aspire 5610Z
Aspire 5620
Aspire 5630
Aspire 5650
Aspire 5670
Aspire 5680
Aspire 5710
Aspire 5710G
Aspire 5710Z
Aspire 5710ZG
Aspire 5715Z
Aspire 5720
Aspire 5720G
Aspire 5720Z
Aspire 5720ZG
Aspire 5730
Aspire 5730G
Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
Try to remove the device from Device manager, and then reinstall or upgrade the driver.
If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
This is a bizzare fix but it works. Microsoft do not want to know.
I lost my CD Rom drive after installing my mobile phone sotware
Go to http://www.unisupport.net/lang/en/tevion_usb_dvb-t.html
Scroll down the page to:
Download the ArcSoft Universal Windows XP / Vista Patch:
1) Download this patch - just click on this line of text to download
This takes you to: http://www.arcsoft.com/downloads/patch/ArcSoft_Vista_Update.exe
Click run.
Once complete reboot and you will now be able to access your CD rom/DVD RW
It's far less painful than REGEDIT !!!
Step 1: Checking for CD/DVD drive in BIOS
Make sure the drive appears in Setup. The drive has to be detected in the Basic Input/Output System (BIOS) before Windows can see the drive. Check for detection as follows:
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Thanks
acer is **** iv got a acer aspire 5720z laptop and the dvd drivers just stoped working and i cant find the drivers
