Dmm Benjamin Air Rifle Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Benjamin Air Rifle Model 342 not building pump pressure
  1. The rifle had been stored away for many years. Tried to fire a sample shot, found the pressure to be much too weak even after more than normal pumping.
  2. I also noted that the bolt action has abnormal slack. This could also be allowing air-pressure to escape when firing.
  3. Please advice me how to rectify the problem and where to get parts for this madel.
  4. Thanks for your time.
  • 1 more comment
  • Anonymous Apr 12, 2009
    I have the same problem with my air rifle not building up air pressure. Can you purchase parts to rebuild the air plunger? It looks like a leather thick washer. If parts can be purchased please pass along. I have had this rifle for 40 years.
  • Anonymous Mar 25, 2014
    It pump up the
    Pressure .but it will not fire. When pulling the trigger. I don't have a bb in it.
  • Anonymous Mar 27, 2014
    Hi, I have a pump action air rifle which will not built up any pressure. You give it one pump and then it releases it's air when you begin your second pump. Do you have any idea why this may be and how I can fix it. Please and thanks
johnz1313
Level 2:
Scholar:
  • Expert 88 Answers
  • Posted on Aug 29, 2009
johnz1313
Expert
Level 2:
Scholar:
Answers
88
Questions
Helped
61343
Points
225
Springs tend to loose their performance after a few years is air rifles. Check also the seal/o rings on the piston rod and the blow hole. I found waxing it with Vaseline makes it last longer and seals more.
Is a Benjamin BB Air Rifle Model 3100 the same as a Crosman Model 3100?
not at all. the Benjamin has a pump handle like the rack of a shot gun below the barrel. the Crossman 3100 the barrel is what you **** the round in with. the Benjamin shoots pellets and bb's the Crosman only shoots bb's
2answers
I need your expert advice. I live in Katy Texas and house backs up to the largest park in this part of texas. We have larger game animals but my problem is I am being runover by larger varmits. ...
WalMart carries a nice 22 caliber air rifle by Crossman. They also carry the 22 caliber pellets. 1200 fps for this rifle should take care of your varmints.
Dec 13, 2010 • Optics
4helpful
How do i change my benjamin air rifle pump seal?
pyramidair.com has a seal kit. it also comes with a diagram. Benjamin and Sheridan air rifles do not have springs to propel the pellet. also never use vasalin. specifically for a Benjamin or Sheridan you need to use pelgun oil (also found at pyramideair.com). use pelgun oil because it is a non detergent fossil compound) the main intention is to condition the seals every 250 rounds. never use silicon based lube for this gun specifically. silicone lube is for spring air rifles such as break barrels.
4helpful
2answers
Air rifle will not pump up
The cylinder needs to be oiled. Its the same concept as a car jack.
Go to a gun store or a Dicks/Bass Pro/Wall mart for the oil.
43helpful
5answers
Model 342 Benjamin Franklin 22 caliber air gun
I recently purchased a rebuild kit for my 342. I bought the kit from airgundepot. It was the kit for the
392 and I modified it a little. On the new plunger, you have to drill a hole in the center of it the same
size as the pin's smallest diameter. You can use all of the parts in this kit except for the small o-ring. I think it sold for about 39 dollars or so. My rifle was manufactured in 1972 and it fires like new.
Top Dmm Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Dmm Boating Expert? Answer questions, earn points and help others
