I am rebuilding a toyota forklift 2Z engine. I was not sent the the specifications for the head bolts to be torqued down.
SOURCE: bolt torque specs
I have used Haynes service manuals for (hate to admit it) many decades and I recommend you check to see if this one:
http://www.amazon.com/Haynes-Toyota-Automotive-Repair-Manual/dp/1563923513
doesn't cover your engine.
I have found darned few 'holes' in their coverage.
Auto parts stores carry these and I suspect that even though sealed, the sales people will not give you too hard of a time if you explain you want to insure you are getting what you need.
Haynes is not the same as it was 20 years ago before they were acquired by Chilton but the price/utility ratio is still pretty good.
Mostly I'm annoyed by the move to cheaper paper (newsprint)that is fussier, picks up dirt, tears more easily than the better paper of yore.
SOURCE: Engine Bolt Torques- 2005 Chevy Impala/3400 Engine
Head Bolts
Step one 37 ft lbs then tignten 120 degrees more
Rocker arms
Step one 11 ft lbs then tighten 90 degresss more
Upper intake
89 inch lbs
Lower intake
132 inch lbs
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
Short Bolts:
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using FixYa. Roger
SOURCE: torque specs for 1998 tercel 1.5L
Main Bearing Cap Torque-42 Ft. Lbs.
Head Bolts Step 1-33 Ft. Lbs. Step 2- Additional 90 Degrees
Rod Bearing Nuts-29 Ft. Lbs.
Hope this helps
