Garmin nuvi 260W GPS Receiver Logo
Posted on Mar 25, 2009
MY GARMIN 260 gps gives wrong information on non existing rounderbouts on highway,freeway ramps,and destinations, showed arrival flag and map when 40 ks away from town
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
2279
Points
28
There is 2 things u can do... either try and reset the gps .. normally its by holding the power button down. or have u tried up dating your maps.. to do this u will have to jump on to the garmin web site and purchade from them... i know alot of ppl have trouble with garmin, i find that navman is the best :)
We downloaded a European map onto the SD card, however, when we look at maps available, the Garmin 260 is not looking at the map on the SD card. How do we tell the device to use the card to search for the...
You need to download the map to your compute rather than the SD card. When downloading the default destination is the satnav but you can change it to your computer. When it's installed to your computer you then click the windows START button and in the list of programs you'll find a GARMIN folder with a program called MAPINSTALL. Connect the satnav to your computer with the SD card in. Run MAPINSTALL and select the SD card as the destination.
You can get more details of how to do it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Note maps installed to SD cards do not always work with Garmin Nuvis. To give it every chance of success please follow the instructions at the above link about formatting the SD card.
Can you in put a pre selected route in to the Garmin Nuvi 1310 GPS so that i can have the route in turn by turn before i leave home
Sure and your doing the correct thing good thinking, always check the route before you go there are way to many ways to get there....
When you input the destination let it calculate then press the green bar on top where it says which way to turn.... it will then let you see which way its traveling, you can arrow down turn by turn or on bottom of screen press show map and give you the route highlighted with a green flag and checkered flag
My nuvi 780 only displays large freeways and no
Have you checked to make sure that the map is checked "ON"?
Please see this link:
http://www.sharc.net/discus/messages/6/75.html?1253054729
If the map is not checked "ON", you will only be getting the Base Map information (major highways - no street detail) and you wont be able to search for places of Interest (POI's).
- Jim
I recently purchased a Garmin Nuvi 750 GPS. While
you can set the types of roads you want the unit to follow. Highways or otherwise.
1helpful
I CAN'T GET MY GARMIN TO SHOW THE COMPLETE ROUTE MAP IT WILL ONLY GIVE ME DESTINATION OR HOME POINT
When you select your destination, before you select go there is an option for map at the bottom of the screen. That will show you the entire route.
2helpful
Garmin nuvi 250W Car GPS Receiver
When you have the screen showing up the route to your destination, if you touch the box down in the left hand corner showing the estimated arrival time the screen should switch to show your current speed, max speed, compass etc.........
We just used our Garmin nuvi 260w for a trip. From Az to CA it was telling us to exit off every off ramp. It was trying to get us to california using side streets. Is there something we can do so it will...
Press the wrench/tools symbol at the main menu. The select "SYSTEM", make sure you have the "Automobile" mode selected.  Any other will try to take you on every non-freeway route it can.
RustyP
4helpful
2answers
Garmin Nuvi 260 - white screen
Hit the side of the Garmin a few times while it is on. I did this to mine, and now I can see the screen like before.
Late information on ramps
Concerning this issue, GARMIN is already advise and the next update will correct this.
If you really want to go back to 4,10 but that IS not recommended to prevent any bugs , contact GARMIN and they will give you hand to go back.
Ask for Automotive technician ONLINE.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
