Tablets & eReaders Logo
Anonymous Posted on Jun 18, 2013
How do i fix my tablet?
My polaroid internet tablet wont turn on or charge.
Justin
Level 3:
  • Master 2,072 Answers
  • Posted on Jun 20, 2013
Justin
Master
Level 3:
Answers
2072
Questions
0
Helped
432144
Points
5629
First off I was ask do you know if the charger is good? If it uses a USB connector to charge and you have another device with a charger, try swapping it out. Look on the tablet charger for the Volts (V) and the Amps (A) it will probably be 5V and 1-2A if you have a charger with a fairly close rating it should charge the tablet. You may also need to hold the reset button down for up to 20 seconds.
  • 6 more comments
  • razee
    razee Dec 07, 2013
    i want to open it and change the charging jack wahts her board opning sulltion sand me images
  • razee
    razee Dec 07, 2013
    lenovo ce 0700 board opning salution
  • patricia martinez
    patricia martinez Dec 08, 2013
    where is the reset on the next book nx0088hd8g I cant find it
  • Justin
    Justin Dec 08, 2013
    The Polaroid tablets have a small pin sized hole on the back. You need to stick a paper clip in it for about 15 seconds. This is the reset button.
  • Dan Armstrong
    Dan Armstrong Dec 13, 2013
    i am having trouble getting on the internet
  • Justin
    Justin Dec 14, 2013
    Have you been able to get on the internet in the past? Are you on your home wireless? Have you changed the password? You can try going into settings > wireless and tap and hold on your network. You should get a "Forget Network" button. Tap that and try connecting again.
  • djfalcone35
    djfalcone35 Jan 28, 2014
    If its a high end device RadiomShack can unlock it,my son did that to his on x-mas
  • vijustlove Feb 14, 2014
    First check if your tablet can be charged with another charger. If it is the problem of your tablet, I think you need a new charging dock replacement to make it back normal.
Cayla Windham
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 18, 2014
Cayla Windham
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
18486
Points
8
My sister tried to put in the pattern to my tablet and now i am locked out
jose
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 18, 2013
jose
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
18513
Points
6
I dnt remember the patter pasword of my polaroid pmid706 ps help
vijustlove
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Expert 39 Answers
  • Posted on Jun 26, 2013
vijustlove
Expert
Level 2:
Mentor:
New Friend:
Answers
39
Questions
6
Helped
22195
Points
103
First you can check your charger or connector if they are OK. If OK, you can send it to get touch with your tablet Service Engineer or the store where you buy.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
17518
Points
Which replacement screen is suitable for a Tivax mitraveler 7d-4a 7"? There too many don't know which one to choose. Sorry to post here, couldn't post anywhere else
1 Related Answer
Anonymous
  • 4961 Answers
  • Posted on Jun 28, 2012
SOURCE: my polaroid tablet fell and it wont turn on
Bring it in to a repair shop...
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
1helpful
How do I get my A 8 Polaroid tablet to turn on?
make sure you have charged the tablet, or have the power cable on during reset.
Just try resetting again. If it does not work contact the polaroid service centre.
Why won't my polaroid S10 tablet turn on or charge?
Either the Power adapter is damaged or the internal circuit board on the tablet has been compromised. Needs a professional evaluation.
Why is my polaroid MID0748PMP01.133 it wont get past.always return in to the android system reboot menu
Be sure nothing is pressing against the volume button when you turn it on, and that the volume button isn't being jammed down by anything.
How do i reset internet tablet
Hi, I've had 2 of these before i got rid of them. I had to get my friend whose great with computers go in from his pc to open mine, so i could wipe the data before returning. If you call polaroid.com they can give you the steps to do this. Unfortunately it is fried, it may work awile after you get it open, but mine didn't. Hope this helps . I also found out this tablet is a starter tablet like something you buy for your kids 1st tablet. Good luck. JMF
My tablet wont charge what can I do I try to plug in charger but won't charge the battery even bought another charger still dont help
Most likely you are using an aftermarket charger. You may want to purchase another or buy and OEM charger.
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
My polaroid 4.3 internet tablet is stuck on the blue screen that says internet tablet I have tried to reset it and that didnt work....whats wrong and what can I do to try to fix it?
I'm actually haveing the same problem with the Emerson 4.3 tablet, which is basically a clone ofthe Polaroid 4.3. When I figure out the awnser I will make sure to come back and inform you on intructions! :) ~Tim Silence
2helpful
2answers
Why won't my Polaroid 7" tablet charge?
My polaroid does the same thing just hold the charger in while pushing it down but it will take a while
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
