Watches Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Watch going in reverse
My Swiss army watch started going in reverse after changing what I thought was a dead battery. Th previous battery was an energizer 370/371.
Replaced with aVarda 371.
Any Ideas?
  • ag306 Mar 23, 2009
    Tried removing the battery. Waited 15 minutes and reinserted the battery. Watch is till going backwards.
  • ag306 Mar 24, 2009
    Battery can only be put in one way. If it installed upside down contact cannot be made to both sides of battery.
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 23, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814226
Points
13579
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
  • Arturs Kalnins
    Arturs Kalnins Mar 24, 2009
    Sorry if it did not help.
    Are you sure you put everything back exactly the same way as it was?
    I came accross the same situation in my early watchmaking years, but that was my fault as I replaced the coil ends the other way round, so, it was quickly sorted after some time of wondering.
    I don't think that you've been misplacing any parts as for replacing the battery you just need to undo the contact.
    Try this- get the battery out again and put it back other way round. If this doesn't work , get the battery out and let me know.
Wenger Swiss Military watch won't run after battery replacement. What to do?! Please
I am thinking you are talking about a Wenger watch, so question edited from 'Wegnar' and the word 'watch' added.
Question moved from Cellphones category to Wenger Swiss Military Watch..
Are you a Watchmaker or a Jeweler? Have a read. My guess is wrong battery, wrong voltage, dead battery or reverse polarity, or bad connection.
https://www.fixya.com/support/r27181038-changing_watch_batteries
Swiss army watch 241083, what battery does it take
Any Brand, Type 371 1.55v. I replaced the same Swiss Army Victorinox Infantry Watch model 241083 specifically with the Energizer 371BPZ Zero Mercury Battery. BTW, the replaced original was also a 371.
1helpful
Im trying yo change the battery how do i open i know thers two ways one is unscrewing the back of the watch the other is like you open a can of paint i try both and none work what should i do or try now?
the Swiss Army watches I have dealt with have all required a Rolex back wrench, it costs in excess of $100.00, they most charge $7.50 to replace the battery and that includes the battery.
Does the Swiss Army Wenger Alpine 72558 Wrist Watch take a battery?
Yes, it has a Swiss Quartz movement, so a battery is what makes your watch work. Need a new battery? Take it an authorized dealer or other business that has the right tool to open the case. It's not worth ruining an expensive watch just to save a couple of dollars to change the battery.
1helpful
How do you open back to change battery?
Swiss Army watches require a special tool. You will need to call your local jewelers and ask if they do Swiss Army watches as not every jeweler has the tool to do it.
Good luck
25helpful
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
12helpful
Wenger watch second hand pauses and skips ahead 4 seconds, it's keeping time find. Seems to just have started.
That is a low battery indicator. It will do that until the battery is replaced or is dead. When it does that it means its time to change the battery.
7helpful
Replacing battery on wenger swiss watch
Hate to say it but Wal-mart has the tools; seems like they'll do it for free if you buy the battery
Wenger watch
swiss army watch had battery replaced after stopping, will not restart, replacement battery new and good.
3helpful
Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
