DOESNT WORK AT ALL!
Double click the icon in the toolbar. Click the device settings tab and then hit setting. select buttons in the list on the left side. Hit the plus sign(maximize) and select scroll up button action....scroll down button action...Etc. For each action select what you want it to do and just hit apply and move to the next. Once you have selected the action for scroll up, down , left, and right hit apply again just to be sure and try it. It should work. I just did it on my 5630 but Im assuming it works the same.
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
5sd4e
You need to go to www.synaptics.com , go to support and click drivers. After that, choose your operating system and go from there.
Windows vista........
This worked for me!!!
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4109&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
All i did was to fix mine was click on the touch pad button on the task bar and clicked scrolling then changed the speed hit apply then put it back to my perfered settings and hit apply again.
it fixed my touch pad scroll and my connected mouse scroll
hope that helps =]
I deleted the touch pad and rebooted, it was reinstalled as new hardware and then started to work again.
Start-Control Panel-System-Hardware-Device Manager-Mic e and other pointing devices- click + -right click and delete touchpad- Reboot- Hardware reloads- Reboot.
Try to install "synaptics pointing driver" from acerpanam.
Have you got the drivers for pc notebook if so re-install board drivers and mouse pad or touch pad drivers and if this dosen't resolve the problem then take it for repair. good luck on this one
if you e-mail me with more details I'll try and look for you.
1 make of laptop.
2 operating system you are on.
3 run dxdiag and save info from this on laptop and e-mail me with it and I'll see if I can find drivers for you.
my e-mail address is [email protected]
this is all I can sugest at moment.
SOURCE: 4 way scroll scroll button IN MY ASPIRE 5100
My 4 way scroll works on & off, usually only doesn't work for a few hours or so, but it's REALLY annoying! Will that fix this problem as well?
SOURCE: THE 4-way scroll button IN MY ASPIRE 5100 DOESNT WORK
try to install "synaptics pointing driver" from acer website.
hope it'll work
I think ur laptop have keyboard problem.Better to u take from nearest service center.
for touchpad, try to remove the battery.
for 4way scroll pad, try to re-install drivers, you can download the driver from acerpanam. they call it, synaptic pointing driver.
I dont have it, do you know where can I download them?
Thank you so much, this is the best technical support that I ever tried, you are so nice, outstanding work. thanks!!
My four way scroll button on my acer aspire 5100 does not work anymore.
I have windos Vista and i dont know how to make it work again.
Please help me ?
Acer Aspire 3100 laptop 4-way scroll button on the pads does not work.
I have Vista also. What should I do?
I haven't tried to resolve the problem. Nothing more but to contact you.
thanks.
my scroll doesn't work
i also have anAcer Aspire 5100 and the 4-way mouse scroll does not work. can you helpme... I have already gone to the control pannel and into the mouse trouble shooting and that didn't help at all... Cecy
where do i find drivers for my 4-way scroll bar it doesnt work after i installed vista...
I have a 5630 but i think that the scrol button is the same. It has ranomly stopped working and i have tried looking through the control pannel and things but nada. I have tried to download drivers but to no avail. Please help.
same as above
My scroll button doesn't work anymore after the last Vista update (apr 2008). Same problem for my orbicam and USB mouse
keyboard is frozen on my Acer Aspire 5100 PC Notebook. Nothing is working!!
my mouse pad does not work at all. the computer says the device is working properly. I uninstalled it and now I am looking to download new drivers
The 4 way scroll button in my Aspire 5100 doesn't work either
acer 5100 no 4 way scoll
no 4way scroll on acer 5100
right click tray icon- device settings tab -settings button-virtual scrolling list or defaults-etc
my pointing device doesn't work even i already installed the driver
the four way scroll button on my acer aspire 5100 doesn't work can you help me to find a solution on this problem...tnxs by klitz24
acer extensa 5420; had for one week, touchpad scroll no longer works and neither does scroll button below the touchpad.
Reading other posts, there is no touchpad option under pointing devices in control panel; not sure what to try now.
4 scroll stopped working
the button that i can use to scroll stopped workin on my laptop an i been tryin to figure out why it hasnt been workin.any suggestion's?
with me same problem
im typing on my new acer aspire laptop and the scroll isint working . Before this morning , it was working perfectly, but all of a sunden it stopped.
what is wrong!? i only had it for 3 days!
