I have 3230 handset but when i try to cunnect blue tooth
phone said " unable to perform bluetooth opration" ples suggest me what i do to solve this problem
You go to the cellphone repair it b'cuz thas is very dangerous problem maybe we can program.if not working we have no choice we need to reheat the part of bluetooth fro refreshing parts
My dear, two things are involved. It is either that the devise you are trying to pair can not connect with your phone, or the device is bad, or still. That your phone can not search and see the device. try useing another blutooth device to check if problem persists. . . . .. . . . . . Thank you
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
Hi, First: better use kasperaskey anti virus. If your desktop pc or laptop has antivirus, have your pc scan your fon memory through bluetooth, or usb cable
OR: If you have Virus On mobile 1 - remove memory card. 2 - dial *#7780# or *#7073* 3 - It format your Phone 4 - Format memory card. and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone. Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone and unlocktotalk.com/UnlockCodeInstructions.htm),
Hi, first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone. You can use this link to see how to flash your phone. (hubpages.com/hub/How-to-Flash-your-cell-phone) and (unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
