This means the signin API is locked into the bridge.
You need to run "clearapi" to clear the hung api connectin slot.
Login with dcbguest , navigate to /usr/dcb/bin
use "dumpapi" to list the active signins along with api slot.
Then use "clearapi" to clear the respective api slot.
This will fix your problem without reinitializing the bridge.
One way is to plug it in to a pc or laptop without the memory card the save the pictures on the pc. After put the memory card in the camera and move the pictures in the camera again so it goes in the memory card. All pictures you take with the memory card automatically go in the memory card.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes... thank u!!! rate me!!
Yes it will. The door activates a micro switch that cuts power to the camera when open to prevent accidental removal of the card and loss of pictures stored on the card. You can bypass this switch with either a solder "bridge" or remove the switch and use a piece of wire to bridge the pads on the board.
If you are using just component cables it's as simple as plugging them into the appropriate ports on the back. One nice feature of the HT-S780 system is the multiple digital audio ports and the ability to map them as you like.
