My dishwasher keeps stopping during the wash cycle and both the start and finish lights start flashing. The start light is flashing continuously and the finish light flashes once every 10 flashes of the start light. What could the problem be?
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
SOURCE: dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
